Activity › Forums › Apple Final Cut Pro › Magnetic mask playback
Posted by Frank Valtellina on January 13, 2025 at 4:10 pmHi everyone, has anyone experienced using multiple magnetic masks on the same clip in Final Cut Pro 11 and noticed that playback stutters? The strange thing is that even after rendering the clip, it still plays back with stutters. The only way to view it correctly is to export it.
Ben Balser replied 10 months, 2 weeks ago 5 Members · 8 Replies -
Doug Metz
January 13, 2025 at 5:16 pmHey Frank,
Have you tried to set the Viewer’s quality setting to prioritize performance? It might help.
I’ve not tried multiple magnetic masks on a single clip… what hardware are you running?
Devrim Akteke
January 13, 2025 at 5:30 pmNever had that kind of problem. Even on a slow iMac, it plays very well. What are the properties of the video, 4K, 50P, etc. maybe it is a processor-intensive codec. Maybe you just need a restart. 🙂
Frank Valtellina
January 13, 2025 at 5:39 pmI’m using a 16-inch MacBook Pro with the M1 Max chip. If I apply a single magnetic mask to the clip, there’s no issue. The problem arises when I apply two or more masks and add some additional effects or clips on the upper layers. The footage is 4K 24p ProRes LT. However, the strange thing is that even after rendering the clip, it still plays back with stutters.
Devrim Akteke
January 13, 2025 at 5:45 pmThe first thing that comes to my mind is Prores LT. That’s not a codec I prefer. I had similar problems many years ago with just regular clips with no effects. I am not sure but can you try it with another video with another codec and see the result?
Frank Valtellina
January 13, 2025 at 5:52 pmI don’t think it’s a codec issue. I’ve tried creating Proxy files H264, but it didn’t make any difference. Again, the strange thing is that even after rendering it, it still plays back with stutters.
Judy Murphy
November 5, 2025 at 12:01 pmYes. Multiple magnetic masks are very GPU-heavy in Final Cut Pro, and FCP often can’t fully use render files for them. So playback stutters even after rendering, but exports look fine. The fix is to bake the effect (Render & Replace or export a ProRes copy) or use optimized/proxy media.
Ben Balser
November 5, 2025 at 7:45 pmPersonally I’d never put two magnetic masks on one clip. Duplicate the clip on top of itself, apply one mask per clip. Some effects won’t work with multiple instances on one clip. And yes, the magnetic mask is very playback intensive.
