Activity Forums DSLR Video Magic Lantern Questions
  • Magic Lantern Questions
    Posted by Ben Edwards on February 24, 2011 at 5:20 pm
    Hi All,
    Thanks to Jonathan Ziegler, I have now got ML working on my 550D.
    When I put the SD card with firmware in it and power up it starts. Originally I though I kept a card to boot the Camera and then could change card but when I remove card camera powers down. Do I need the firmware on all cards?
    Also are there any guides/documentation to using ML. I have looked on the ML Wiki but cant find anything.
    Regards,
    Ben
    Suley Suleman replied 15 years, 2 months ago 6 Members · 5 Replies
  • Steve Crow
    February 24, 2011 at 6:46 pm
    Yes, I’d like to know the answer to this too 🙂
  • Rafael Amador
    February 25, 2011 at 2:19 am
    I don’t work with DSLRs, but as long as I know the software needs to be loaded every time you power the camera up. So, yes; you need the ML firmware on every card.
    rafael
    http://www.nagavideo.com
  • Pete Burger
    February 27, 2011 at 10:56 pm
    Can confirm Rafaels answer. ML has to be on every card. If you delete the ML files or format the card, ML is gone.
    Don’t know which version/build you have, but in the ML version that I use there’s a PDF included, that gives (more or less) detailed information about all features.
  • Thomas Pohl
    June 7, 2011 at 7:47 pm
    Which ML version are you using? I tried the 0.2.0 Version on the 550d from december and the last from 31th of may. Both are too buggy to use it seriously.
    Cheers
    Thomas.
    https://www.footage-online.de – RED footage and more available in HD, SD and RED RAW R3D
  • Suley Suleman
    July 2, 2011 at 4:17 pm
    What version ML do you use? Would you be able to provide a link to where you dl’d from with the PDF or upload the manual. Also what version would you recomend for a 550d?
