Activity › Forums › Avid Media Composer › Magic Bullet looks won’t see AVID colour correction.
  • Magic Bullet looks won’t see AVID colour correction.
    Posted by Jamie Havill on January 8, 2009 at 10:27 pm
    I’ve corrected an image using AVID’s CC facility, and when i then apply magic bullet to the clip it doesn’t recognise the colour correction, and applys changes to the image based on what it originally looked like before I colour corrected it in AVID. Can only shed some light onto why this is?
    Kris Anderson replied 17 years, 8 months ago 3 Members · 2 Replies
  • Michael Hancock
    January 8, 2009 at 10:31 pm
    When you apply the Magic Bullet effect, hold Alt as you drag it and don’t release Alt until the effect is applied. If you don’t hold Alt it removes the first effect (in this case, Color Correction) and replaces it with the second effect (Magic Bullet).
    Michael.
  • Kris Anderson
    January 11, 2009 at 11:23 pm
    I’ve also found that when nesting effects using Magic Bullet the fx nested underneath it need to be rendered or else I get a black screen when entering the MB editor. But I looove MB.
