Activity Forums Adobe After Effects magic bullet looks won’t render in full res
  • magic bullet looks won’t render in full res
    Posted by Jo Roy on August 30, 2014 at 7:00 pm
    I have a problem with magic bullet look, using AE CS6.
    I just installed the latest update via red giant link, and the problem remain.
    The footage is prores 422 4.5k, but in a 1080 comp. ( I also try it with the original size, same thing happen)
    If it’s at half res or less, everything work fine.
    But the second i put it in full res, it become black, and render that way too,
    so it’s not just a preview issue.
    By unchecking effect one at a time, i spot the problem on Look.
    If i put Look on an adjustment layer, everything work fine again.
    But because of the tracking and because a person pass over the 2nd shot(which have another look applied), i am trying to avoid the option of kreyfaming the adjustment layer.
    Any ideas?
    Jonathan
    Jo Roy replied 12 years ago 3 Members · 3 Replies
  • Chris Wright
    August 31, 2014 at 6:42 pm
    It might work if you put it in comp size 720×480. I’m guessing you have the SD plugin not HD.
    I’m keeping this post up because some people don’t buy the right plugin
  • Walter Soyka
    August 31, 2014 at 8:23 pm
    I bet this is a GPU problem. 4K is a magic number that limits texture size for some GPUs/drivers/software — and that might be why it works at half res (2.25K), but fails at full res (4.5K).
    Open the Looks interface, then under its File > Preferences, change the renderer from GPU (OpenGL) to CPU and see if that helps.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Jo Roy
    September 1, 2014 at 12:22 am
    It works!
    Thanks Walter!
