Activity Forums Adobe After Effects Magic bullet looks suite crash
  • Magic bullet looks suite crash
    Posted by David May on May 26, 2008 at 7:00 pm
    Hi all.
    Im using the magic bullet looks suite on my cs3 ae composition, and aside from not being able to use presets, it works great. Until i try and render. The render (even a low quality high speed one) will abruptly stop, and a message will pop up saying “After Effects has crashed after trying to invoke “looks suite”. The weirdest thing is that this crash will generally be a minute or so into the render, meaning that many of the first frames with the exact same look settings have gone through fine. magic bullet looks isnt exactly new, and its meant to be compatible with cs3 (like i said, presets dont work, but everything else does), so any ideas why I have this this crash?
    Cheers
    Dave
    Rex Monga replied 15 years, 3 months ago 3 Members · 5 Replies
  • Michael Gleissner
    May 27, 2008 at 4:30 pm
    You might try rendering out as numbered frames rather than as a self-contained Quicktime file. That may solve the issue for you.
    I have noticed that Magic Bullet’s code isn’t always the cleanest and anything you can do to simplify and dumb it down tends to help.
    Michael
  • David May
    May 27, 2008 at 10:29 pm
    I got sick of its unreliability (couldnt load presets), so Im just using the curves effect in color correction to get the desired look. I will hopefully try and fix it when I have more time, as it is expensive software, Im just annoyed it doesnt work straight up.
    Thanks mate
  • Michael Gleissner
    May 27, 2008 at 10:36 pm
    [David May] “…as it is expensive software, Im just annoyed it doesnt work straight up.”
    Red Giant’s customer service stinks. They’ve always been one of the worst in the business and because of that, we don’t use them if we can avoid it.
    My sympathies are with you.
    Michael
  • Rex Monga
    June 13, 2011 at 5:19 am
    hi guys
    u can solve this problem, just right click on after effect.exe and go to property
    then click on compatibility
    choose windows xp (srevice pack2)
    check on run this programe as an administrator
    regards
    regards
    rex monga
  • Rex Monga
    June 13, 2011 at 5:25 am
    hi guys
    regards
    rex monga
