Activity Forums Apple Final Cut Pro Legacy Magic Bullet Looks gets pixilated with Final Cut Pro.
  • Magic Bullet Looks gets pixilated with Final Cut Pro.
    Posted by Kristian Vestergaard jensen on August 24, 2011 at 9:23 am
    Hey everyone,
    Im having some problems using Magic Bullet Looks with Final Cut Pro 7. When I apply looks to clips in my timeline the clips gets pixilated. It works fine with After Effects and in stand-alone-mode. So I figured that it has something do to with my settings in FCP.
    Can somebody help me?
    Best regards
    Kristian V. Jensen
    Denmark
    Kristian Vestergaard jensen replied 15 years ago 2 Members · 4 Replies
  • Ryan Rivard
    August 24, 2011 at 2:10 pm
    Kristian,
    I’ve actually encountered the exact same problem. Have you had any luck figuring out a solution?
    I’m also running FCP7 and MBL2.0
    Ryan
  • Kristian Vestergaard jensen
    August 24, 2011 at 2:17 pm
    Nope.. So I hope there’s somebody in here who can help.
  • Ryan Rivard
    August 24, 2011 at 2:36 pm
    Kristian,
    I actually found a solution with a bit of digging. It was in another post. All you need to do is go to Sequence>Settings>General Tab and set the field dominance to “None”. That fixed it for me. According to the other post, Red Giant is aware and attempting to fix the problem.
    Good Luck!
    Ryan
    August 24, 2011 at 4:03 pm
    Thank you so much Ryan.. That fixed it.
