Activity Forums VEGAS Pro Magic Bullet Looks crashes Sony Vegas Pro 13
  • Magic Bullet Looks crashes Sony Vegas Pro 13
    Posted by Liubomir Smekhov on October 30, 2016 at 1:19 am
    Hello.
    The issue is the following: I have Sony Vegas Pro 13 and Magic Bullet Suite 11.1.0 installed on laptop HP Pavilion dv6, Win 7 (x64), Radeon HD 3000 – and everything works smoothly. BUT: every, EVERY next version of Magic Bullet Suite (right up to the latest 13.0.0) on the same laptop and with the same SVP 13 doesn’t work at all and displays identical behavior: installs correctly, shows up in Media FX in Vegas, adds with no problem to any clip (Looks in particular). But the second I hit “Edit Look” – “Vegas Pro has stopped working” window pops up and only option left for me is to close the program. I’d like to emphasize: this kind of thing happens to every version higher than 11.1.0 (which as I said works perfectly on the same machine).
    Can anyone give any kind advise on what seems to be the problem and how to solve this issue?
    Thank you very much
    *to begin with, the only reason I started messing with higher versions of Magic Bullet Looks is that 11.1.0 version doesn’t have a LUT Buddy plugin, which I would very much like to use instead of VisionColor LUT plugin, which by the way works fine but doesn’t give me the control I’d like to have.
    Liubomir Smekhov replied 9 years, 10 months ago 2 Members · 2 Replies
  • Peter Honig
    November 2, 2016 at 1:11 am
    I had a somewhat similar problem but in Adobe CS6. Red Giant support told me to update my graphics driver and the problem was solved. Perhaps this is your problem as well.
    Peter
  • Liubomir Smekhov
    November 4, 2016 at 1:56 pm
    Thank you, Peter,
    although I’ve already tried to update my video card driver and it said the driver didn’t need to be updated, I will definitely try updating it again.
    Any other suggestions? Anybody?)
