Activity Forums Adobe Premiere Pro Magic Bullet Editors v. 2 crashes PPro 2
  • Magic Bullet Editors v. 2 crashes PPro 2
    Posted by Adam Fischer on August 10, 2006 at 4:47 am
    I downloaded the demo of Magic Bullet Editors v. 2 for PPro to try it out. I used v. 1.5 on a PPro 1.5 system a while ago, and now I have a new PPro 2 system of my own that I would like to buy it for. I figured I’d download the demo before buying it to make sure it worked okay with my new system. It’s a good thing I did!
    The problem is that after installing it, when Premiere is starting up and you can see that it’s starting to load the look suite plugin on the splash screen, I get the Windows error message that Premiere has encountered an error and has to shut down. I checked the website for an update or fix and they didn’t have anything that solved the problem.
    Any suggestions?
    Aanarav Sareen replied 20 years, 1 month ago 2 Members · 1 Reply
  • Aanarav Sareen
    August 10, 2006 at 7:59 pm
    [FischTale] “The problem is that after installing it, when Premiere is starting up and you can see that it’s starting to load the look suite plugin on the splash screen, I get the Windows error message that Premiere has encountered an error and has to shut down. I checked the website for an update or fix and they didn’t have anything that solved the problem.”
    Do you get a blue-screen error? Also, take a look at the Magic Bullet forum on the Cow, as that forum is monitored by Red Giant itself.
    Aanarav Sareen
    premiere@asvideoproductions.com
