Activity › Forums › Apple Final Cut Pro Legacy › Magic bullet causing jumpy footage.
  • Magic bullet causing jumpy footage.
    Posted by Solon Quinn on April 17, 2008 at 5:50 am
    I recently shot some footage on the DVX 100b. I applied various magic bullet filters onto the footage and it worked perfectly. Today I loaded some more footage on the timeline and applied the same filters and for some reason the footage is jumpy. This is extremely frustrating because both clips are on the same timeline and and one is jumpy the other is not. Does anyone have any theories to why this is happening?
    Mark Maness replied 18 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Solon Quinn
    April 17, 2008 at 8:11 am
    I’m now finding that if I place two filters eg. the bleach bypass filter as well as the ls white diffusion 5.0 the flicker goes away, however if I just use the white diffusion alone it still flickers.
  • Mark Palmos
    April 17, 2008 at 10:11 am
    hello solon
    are you applying the exact same setting to both?
    im curious about your name, the only solon i have met is my step-father, and he is greek… your surname is quinn (which is definitely not greek!) so…
    nice name btw, solon was the man who “invented” democracy – im sure you know that.
    cheers,
    mark.
  • Bouke Vahl
    April 17, 2008 at 2:40 pm
    What could be the case is the following:
    (i got bitten by this quite recently)
    Interlaced video starts and ends on half a line.
    Thus, if you blur it, every other field has slightly more black in it.
    You’ll notice it by flicker left top/right bottom.
    Solution: crop 1 or two lines top and bottom before applying the Magic Bullet effect.
    hth
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Solon Quinn
    April 17, 2008 at 9:11 pm
    Hey Mark,
    Well my parents had a grand old time naming their kids haha. My name is Solon, and my brother’s name is Shaman. I think I received the better of the two. I’m actually South Korean, adopted by German Irish parents, who then gave me a Greek name. I am a living breathing melting pot.
    -Solon
  • Solon Quinn
    April 17, 2008 at 9:13 pm
    So I’ve semi-fixed the problem but not really. I’ve found that if I apply two magic bullet filters, then there is no jumping of the picture. However one filter alone still does cause jumping. Any suggestions?
  • Mark Palmos
    April 17, 2008 at 10:14 pm
    hi
    yeah, that is a melting pot for sure!
    solon was great, had impeccable integrity and was a lawyer; not as famous as aristotle, socrates or plato but i think even more important in his stand for human rights.
    cheers mate
    mark.
  • Mark Maness
    April 21, 2008 at 3:55 pm
    I have to ask….
    What res is your footage? Is it HD or SD?
    I ask this only because we had a situation a couple of weeks ago and I found that the filter was setting my HD footage to lower field dominance. When in reality, HD footage is upper field dominant. SD footage is lower field.
    This will cause your footage to become jumpy or jittery. Take a look to see if this is happening.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
