Magenta fringing using Primatte Keyer with Blue Screen Background
I am using After Effects CS4 and Primatte Keyer Pro to key bluescreen 2k ProRes footage from RED RAW 4k.
The bluescreen was lit exceptionally well and there is no spill on to the subject but every time I try and pull the key I am left with a magenta colored fringe around the dark, soft areas of the foreground subjects. I’ve tried using all the refine tools to fix the problem to no avail.
I feel that it has something to do with the Edge Color Replace being set to compliment but no other setting produces a better result.
What could I be doing wrong? Please advise.
