Activity Forums DVD Authoring Maestro Sync Problem
  • Maestro Sync Problem
    Posted by Rebecca Davis on May 26, 2005 at 11:20 am
    Hello,
    I am experiencing sync problems of about 6 frames in the audio stream. The sync is not gradually getting worse, rather it stays a consistent 6 frames ahead or behind. I noticed in my asset bin that the duration of the mpeg and ac3 streams are not the same. Furthermore, I’ve noticed that when using non-drop frame masters, the durations between the encoded files are the same. Has anyone else experienced this problem? Has anyone got a fix for this?
    The specifics of my current project are:
    BSP Drop Frame Masters
    Sony DVWA510 DigiBeta Player
    Spruce MPX 3000
    Any insight would really be appreciated.
    Bill Stephan replied 21 years, 2 months ago 3 Members · 2 Replies
  • Chris Borjis
    May 26, 2005 at 1:15 pm
    If the audio stream is not the same duration within a few
    frames, thats the problem first and foremost.
    Does it happen on a short clip?
    I would encode for 1 to 5 minutes and test that first.
    Probably not Maestro causing it.
    Try capturing the drop-frame masters as non-drop.
    Doesn’t make sense but it could fix it.
    Let us know the solution when you find it.
  • Bill Stephan
    May 26, 2005 at 4:08 pm
    Drop frame time codes do somtimes cause problems in certain authoring apps. I agree with Borjis that you should try encoding non-drop frame.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
