Activity Forums Apple Final Cut Pro Legacy Mac’s Disk Utility RAID maker…
  • Mac’s Disk Utility RAID maker…
    Posted by Tad Newberry on March 19, 2011 at 7:47 pm
    I’m finally getting a RAID going and thought i would start with Disk Utility’s RAID creator. What do you guys think of it? I read through the Disk Utility helps and it sounded pretty good, though i rarely hear it talked about hear. My plan was to do a striped RAID for speed using (2) of my internal Seagate 1.5 TB Barracudas (7200 rpm), and then maybe down the road put this first RAID set into a redundancy mode going to an external (USB 2) 2TB Seagate Barracuda LP (5900). How does this sound? Would either of these setups help in FCP, or should i stay away completely from Disk Utility?
    I mostly work with ProRes 422 files, and get decent performance in FCP, but a little more speed would probably help.
    thanks for helping out a bonehead!
    __________________________
    FCS3
    2.66 GHz Quad-Core Mac Pro
    6GB RAM
    NVIDIA GeForce GT 120
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Rich Rubasch replied 15 years, 6 months ago 5 Members · 12 Replies
  • 12 Replies
  • Cameron Clendaniel
    March 19, 2011 at 7:58 pm
    I’ve used Disk Utility to setup many internal RAID 0 arrays – never had a problem (although of course RAID 0 carries obvious risks).
    Cameron Clendaniel
    film editor, NYC
    http://www.camclendaniel.com
  • David Roth weiss
    March 19, 2011 at 8:10 pm
    [tad newberry] “My plan was to do a striped RAID for speed using (2) of my internal Seagate 1.5 TB Barracudas (7200 rpm), and then maybe down the road put this first RAID set into a redundancy mode going to an external (USB 2) 2TB Seagate Barracuda LP (5900). How does this sound?”
    Striping two or more drives together at RAID 0 is always a good thing, but it’s really just a good start in the right direction. You’ll probably kick yourself for taking this long once you start to really appreciate the benefits and you’ll soon begin to covet the real deal, at which point you’ll graduate to a truly fast array. And, you’ll thank your stars for Thunderbolt soon enough…
    The redundancy thing via a USB connection sounds a little odd to me… It will most likely just slow down your primary RAID. I’d say, either do manual backups or go with a full-blown RAID 5 or 6 setup, which requires at least 3 drives (preferably 5 to 8) and a hardware controller.
    Keep in mind, backing up media files most likely is not something most of us need to do every single day. It’s most important right after you ingest new material. So, it’s not like manual backups are so time-consuming and labor intensive that you need to sweat about them.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Tad Newberry
    March 19, 2011 at 8:29 pm
    is the “obvious risk” that there is no redundancy no redundancy? if so, that would’ve been the point of the concatenated RAID with the external USB drive (or, i could move stuff around and use a FW800 drive as well)
    FCS3
    6GB RAM
  • Tad Newberry
    March 19, 2011 at 8:38 pm
    Thanks David…yes, i’m sure i’ll be kicking myself quite soon! : ) I guess i’ve just been hesitant to lose actual drive space for speed, but prices do keep dropping and sizes keep going up. Rather than using a USB (2, haven’t gone to USB 3 yet) drive, i could use a FW800 or go get an eSATA card and go that route for an external redundant drive.
    FCS3
    6GB RAM
  • Tad Newberry
    March 19, 2011 at 9:26 pm
    And another RAID-newbie question: do i put ALL types of “media” files on the RAID? still images, QT’s rendered out of Motion, etc? And if a Motion project was on the RAID, would Motion run a little smoother or is that completely a RAM consideration?
    FCS3
    6GB RAM
    March 19, 2011 at 9:52 pm
    Yes, the risk of RAID 0 is that if one drive in the array goes down, you lose everything. And it does happen – and I’ve lost system drives too so backups are of course critical in any workflow. I use my internal RAID 0 for media only – footage, stills, outputs, etc (and only if I have backups elsewhere) – and as a scratch disk for FCP renders, etc. Anything that needs speed. Project files I would not put on a striped RAID and I doubt you would see any speed boost doing so. The speed of Motion is largely dictated by your video card.
    Cameron Clendaniel
    film editor, NYC
  • Tad Newberry
    March 19, 2011 at 10:16 pm
    Thanks, Cameron!
    FCS3
    6GB RAM
  • David Roth weiss
    March 19, 2011 at 10:52 pm
    [tad newberry] “I guess i’ve just been hesitant to lose actual drive space for speed”
    You don’t lose drive space with RAID 0. And, when you graduate to RAID 5 or 6 the security factor is so high that the space you lose is not really a concern, because you just sleep better.
    David Roth Weiss
    Los Angeles
  • Tad Newberry
    March 19, 2011 at 11:06 pm
    thanks, ya, i will look forward to graduating soon. thanks again for your and cameron’s pointers…
    FCS3
    6GB RAM
  • Jason Brown
    March 20, 2011 at 12:13 am
    I have this type of setup, 3x 1TB internal 7200rpm. All striped as raid 0. My redundancy is a time machine backup to an external lacie big quadra (6 TB) in raid 5.
    I originally had apple raid card installed, then setup raid in disk utility. Found out later that raid card wasnt even being used. All research I did lead me to the result that a software raid was just fine.
    -jason
