Activity Forums Apple Final Cut Pro Legacy MACPRO vs Quad (G5)
  • MACPRO vs Quad (G5)
    Posted by Paolo Rec on April 18, 2007 at 6:44 pm
    I have bought a new Quad Intel 2.66 with 5Gb ram and Ext Sata drive.
    With Quad Intel I can play 4 PiP layers DVCPRO50 footage and then I Have red line.
    With Quad G5 same configuration I can play 11 PiP layers with same DVCPRO50 footage.
    My friend has tried with his Quad Intel 3ghz with DVCPRO50 footage, only 4 layer then red line.
    Why this big difference with these two computer?
    I use FCP 5.1.4
    Thank you
    Paolo
    Rec Studio
    Italy
    Paolo Rec replied 19 years, 5 months ago 3 Members · 3 Replies
  • Walter Biscardi
    April 19, 2007 at 2:26 am
    Realtime is affected by hard drive speed, NOT processors. Are you all running the identical hard drive configuration?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • David Bogie
    April 19, 2007 at 4:38 pm
    > Realtime is affected by hard drive speed, NOT processors. < It's that simple? Cool. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Paolo Rec
    April 19, 2007 at 5:44 pm
    Thank Walter, the strange is that on my quad G5 I have e normal Lacie Fw800, and on my Quad Intel I have a Raid Sata with 140mbs. I have connect FW800 on my quad Intel but the same problem.
    I think it can be a FCP problem with intel processor because I have the same problem on my MacBook pro and a test is been done by my Aja’s dealer. On is Macpro 3.0 Ghz only 4 layer then red line. (with DVCPRO 50 file)
    Thank you
    Paolo
