Activity Forums Apple OS X MacPro 3.1 OS10.6.8 will not delete files in trash (came from Raid 0 hard drive)
  • MacPro 3.1 OS10.6.8 will not delete files in trash (came from Raid 0 hard drive)
    Posted by Hal Beery on February 11, 2015 at 7:17 am
    MacPro 3.1 OS10.6.8
    Spring Cleaning… deleting duplicate media files on external hard drive (1.03TB). BUT… the files from a two drive raid on eSata port with Raid 0, will not delete. Every time I press the “delete ALL files” or even the “delete unlocked files” the delete window disappears and no action proceeds.
    I have already deleted files from a CalDigit Mini two drive Raid 0. No problem.
    Your wise councel please!
    Hal Beery
    Sanjay Productions
    Tamil Nadu, India
    Michael Locke replied 11 years, 7 months ago 2 Members · 1 Reply
  • Michael Locke
    February 22, 2015 at 6:19 pm
    Skip the trash, Disk Utility is your friend. It will tell you if you have permissions, and if so, you can reformat/erase the drive. Mac OS Extended (Journaled) is the format choice for Macs, if you’ve not used the program much. See if that helps…
