Activity › Forums › Creative Community Conversations › macOS firewall and FCPX
Posted by Oliver Peters on October 26, 2018 at 9:54 pmWhat’s the consensus here about the built-in macOS firewall and FCPX? Especially when connected to SAN/NAS storage. Enable or disable? If enabled – block all connections or fine-tune the settings?
– Oliver
Oliver Peters – oliverpeters.com
Doug Metz replied 7 years, 11 months ago 2 Members · 3 Replies -
Doug Metz
October 26, 2018 at 10:28 pmI’ve got the firewall on – unchecked Block all / checked Automatically allow built-in to receive / checked Allow signed / checked Stealth mode.
No issues with Synology NAS (AFP / SMB / iSCSI). At least, nothing to do with the firewall. SMB has been unreliable and slow, so I don’t typically use it.
Doug Metz
Anode
Oliver Peters
October 26, 2018 at 11:20 pmThanks. Are you finding AFP to be better with FCPX?
Oliver
Doug Metz
October 29, 2018 at 4:24 pmI did some fairly extensive tests on our internal network after purchasing the Synology, and at the time, SMB was half the speed of AFP. I tried turning off packet signing, changing a few other settings that should have helped, but couldn’t get anything near gigabit so I’ve left it on AFP.
Other info – Synology DS1010+ with expansion chassis DX510 – each box is a volume (1 normal share, 1 iSCSI block-level volume) – SNS globalSAN initiator on 2 workstations – ethernet ports bonded – RAID5 – jumbo frames enabled
Due to age, this combo will be retired this year. Synology doesn’t support it anymore and the last DSM version available doesn’t support macOS auto-saving, which causes hard crashes when trying to open and edit files remotely. The SMB implementation also seems to conflict with current versions of the macOS implementation. File copy is still okay, but it really needs to go.
Doug Metz
Anode
