mackie 1202 setup
I’m wondering how best to plug in and out of my mackie 1202 simply for monitoring audio from FCP. Currently, my setup is as follows:
1. FCP 5.1 audio out through Decklink HD Pro
2. Decklink HD Pro audio out through digital AES cable to Behringer Ultramatch Pro converter
3. Behringer converter analog XLR out to Mackie 1202
4. Mackie 1202 out to powered KRK Rokit 5 speakersNow, currently I have the left XLR cable from the Behringer plugged into the LINE IN 1 (1/4″) on the Mackie, and the right XLR cable from the Behringer plugged into the LINE IN 2 (1/4″) on the Mackie. Then I have 1/4″ TRS cables running from the MAIN OUT L/R outputs on the Mackie out to my powered KRK speakers.
Is this set-up correct? Or should I be using the LINE IN 5-6 inputs and the CONTROL ROOM outputs? If anyone can a detailed description of how to wire up this Mackie it would be greatly appreciated. Just need it for correctly monitoring FCP audio for now…
Thanks.
