Activity › Forums › Adobe After Effects Expressions › Machine gun firing
  • John Dickinson
    March 3, 2006 at 12:37 am
    This is called “muzzle flash”. I know that Digieffects Delirium has a muzzle flash effect. Artbeats also sells stock footage of muzzle flashes. Andrew Kramer might have some good ideas as well, he’s been working on this kind of thing lately.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Dan Asselin
    March 3, 2006 at 1:22 am
    You might also look at Particle Illusion if you have access as they have both flashes and spent shell emitters
  • Mike Clasby
    March 3, 2006 at 1:41 am
    You might want to check out these Detonation Film Freebies:
    https://detonationfilms.com/free_stuff.htm
    Tutorial (for Premiere and FCP, but can do with AE) here:
    https://detonationfilms.com/tutorials.htm
    Then for the repeat of a machine gun (600 rounds per minutes if my Infantry memory holds up, so loop it every three frames if 30 fps comp), use this loop expression:
    Loop_out(“cycle”,0)
    See Dan’s tutorial “Animating a Walk Cycle”, by clicking his head above, for details (and project file) on looping.
  • Firstcinemapictures
    March 4, 2006 at 7:18 am
    also check out this software.
    https://fxhome.com/effectslab/
    Darrell
    FIRST CINEMA PICTURES
