Activity › Forums › Adobe After Effects › Machine Gun Fire | Bullet Random
  • Machine Gun Fire | Bullet Random
    Posted by Daniel Elder on June 29, 2009 at 5:16 pm
    I am trying to use a dot in my logo to create a bullet being shot from a machine gun. I would like to simplify the motion for creating maybe 50 + bullets being shot in a couple seconds, so that the {x,y,z) coordinates are roughly the same where the bullet starts, but the bullet ends randomly at the ending (x,y,z) coordinates.
    I was thinking of using trapcode echospace or something like that, any advice on how to simplify this action? Thanks!
    Daniel Elder
    producer
    http://www.luminair.com
    Mike Park replied 17 years, 3 months ago 3 Members · 4 Replies
  • Daniel Elder
    June 29, 2009 at 5:50 pm
    Echospace didn’t do the trick I was hoping for, does anyone have any ideas on this, I have to get something created by days end. ANY advice would be welcome. Thanks
    Daniel Elder
    producer
  • Michael Szalapski
    June 29, 2009 at 6:05 pm
    Particular. You could make the emitter be controlled by a light. Make the size of the emitter very small, but the spotlight’s spread wide enough to hit the space you want.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Daniel Elder
    June 29, 2009 at 6:12 pm
    Thanks, do you have any suggestions on what settings I should use to shoot the bullets from point A which won’t change much, to Point B which will change along the x,y,z axis’?
    Daniel Elder
    producer
  • Mike Park
    June 29, 2009 at 8:53 pm
    Are you viewing the bullets from the side or looking at your target like you are actually holding the gun. This will determine where you put your emitter.
    Using Particular, use a point emitter, change it to directional, change the spread to 0 to line up the direction toward your target by rotating the emitter in the x,y,and z axis. Then, simply change the spread angle until the rounds spread out enough to your taste. You can mess with velocity and even have the rounds die when they hit your layer if you change the settings to bounce and use your target layer as a wall or floor.
    Best of luck
    Mike Park
