Activity Forums AJA Video Systems Machina problems?
  • Machina problems?
    Posted by Adrian Hauser on May 22, 2006 at 11:27 am
    Hi AJA,
    I have been demoing a Xena system with machina for the capture and playback of HD res image sequences.
    I tested a variety of capture presets including DPX and TGA ect. All worked very well. However when I tried to play back some sequences I already had on my Raid array the player would only load a small portion of the actual
    sequence. It would not load the entire directory of frames. I tried this with both short and long sequences and found the same problem in both cases.
    Are you aware of this and do you have a fix for it?
    I am also wondering if you plan to support 3d luts in your player as well as the current supported 2d LUT?
    I would like to see a playlist control (script based) that can load a playlist of clips and apply a different LUT to each clip. Would this be possible in the near future?
    I understand that Luts need time to load and may not be instantaneous. If the change in LUT potentially caused the playback to drop frames or Lose RT playback perhaps you could automatically record to tape each of the clips in the playlist seperately. . a bit like an auto assemble program.
    What do you think?
    Adrian
    Aja Sales department replied 20 years, 4 months ago 2 Members · 1 Reply
  • Aja Sales department
    May 22, 2006 at 4:18 pm
    Hello,
    Thank you for your input on features. many of the things you mention we are looking at for possible future feature upgrades, but as a rule, we do not discuss features/capabilities/products that are not ready or near ready for release. I will certainly pass on your feature wishes, though, and we do appreciate this type of feedback.
    May I ask that you contact our support group for your playback issues? They can be reached at support@aja.com, or by phone at +1 (530) 271-3190. Please make sure to have version and system information handy.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
