Activity Forums Apple OS X MacBookPro spec check
  • MacBookPro spec check
    Posted by Chris Newberry on February 1, 2019 at 6:16 pm
    Hi
    I need to buy a new MacBookPro for editing on the go (have a lovely iMac).
    While I edit with 4k, it’s not multi playered and it’s 100mbps or less.
    I have a tight budget (post Christmas!!) so would the below work.
    I’ve found this one I think I might get.
    Can I get away wiht editing on the move?
    Originally released July 2018
    MacBook Pro 2.6GHz 6-core Intel Core i7
    Touch Bar with integrated Touch ID sensor
    15.4-inch
    16GB of 2400MHz DDR4 onboard memory
    512GB SSD 1
    Radeon Pro Graphics 560X
    I know it’s not the best, but I’ve a decent iMac indoors etc, this is just for out and about, 2nd computer when needed etc. I’d edit off internal SSD or USB/TB drive if needed…
    Chris Newberry replied 7 years, 6 months ago 2 Members · 2 Replies
  • John Rofrano
    February 1, 2019 at 11:33 pm
    That would be more than adequate if you are editing with Final Cut Pro X. That’s the MacBook Pro that I have and I’ve edited on far less. That’s actually a killer laptop. It just doesn’t have the Radeon Vega Pro GPU, but other than that, it’s top-of-the-line.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Chris Newberry
    February 2, 2019 at 8:37 am
    Great! Thank you ☺
    Really appreciate the help
