Activity Forums Apple OS X Macbook Pro vs. Mac Mini?
  • Macbook Pro vs. Mac Mini?
    Posted by Mavis Everett on January 31, 2019 at 5:21 am
    Not sure if this is the right place for this, but I’m looking to buy a new computer. My budget is fairly limited (>$2,500 USD), so my options are pretty much as follows:
    1. Get a 13-inch Macbook Pro (without touchbar), and spec it up to :
    2.5GHz dual-core 7th-generation Intel Core i7 processor, Turbo Boost up to 4.0GHz
    Intel Iris Plus Graphics 640
    16GB 2133MHz LPDDR3 memory
    512GB SSD storage
    … and then just get an external monitor to make up for the tiny screen size. OR…
    2. Get a Mac Mini and spec that up too:
    3.2GHz 6‑core 8th‑generation Intel Core i7 (Turbo Boost up to 4.6GHz)
    32GB 2666MHz DDR4
    Intel UHD Graphics 630
    512GB SSD storage
    Both of these options are around the same price, I just can’t tell which would be better for working mostly in After Effects and Cinema 4D (some octane).
    Any help would be appreciated! I’m not good with tech specs.
    John Rofrano replied 7 years, 5 months ago 3 Members · 2 Replies
  • Paul Dickin
    January 31, 2019 at 4:01 pm
    The 13-inch Macbook Pro (without touchbar) has only two Thunderbolt 3 posts. Connect an external monitor and an external charger, and you can’t connect an external hard drive without unplugging one of the others.
    The Mac mini has 4 TB3 ports + 2 USB 3 posts and HDMI for monitoring. Also it has 4 more CPU cores and doesn’t need an external charger.
    Which make it more practical.
  • John Rofrano
    February 1, 2019 at 11:43 pm
    I agree with Paul, the Mac Mini with 6 Cores and 32GB memory will perform way better than the MacBook Pro with only 2 Cores and 16GB.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
