Activity Forums Apple Final Cut Pro Legacy MacBook Pro Video/Monitor & Storage
  • MacBook Pro Video/Monitor & Storage
    Posted by Raciere Exe on June 22, 2006 at 4:00 am
    I’m looking to set up the following configuration w/ my MacBook Pro, and I’m not quite sure how to do it. Any advice apprecaited.
    I want to use both an external monitor for FCP timeline editing AND a simultaneous s-video monitor out for critical monitoring on my JVC broadcast color monitor.
    – How to get both DVI AND s-video out from my MacBook Pro?
    2. Also, what are most MacBook Pro users using for external storage? The Firewire400 is too slow… I’d like to do an eSata expresscard (ala: https://www.firmtek.com/seritek/seritek-2sm2-e/) and a G-Drive Q with an eSATA input (at https://g-technology.com/Products/G-DRIVEQ.cfm)… anyone using this configuration? Or what about the SeriTek/2EN2 external dual-bay hot-swap SATA enclosure? I’ve NEVER used a SATA enclosure and am blind here… where do you get the harddrives for the enclosure? what kind?
    ANY adivce appreciated! Thanks for any response.
    Kalunga Lima replied 20 years, 3 months ago 5 Members · 4 Replies
  • Ed Dooley
    June 22, 2006 at 4:35 am
    To get broadcast monitoring, you need something that Apple doesn’t provide (look at AJA or Decklink).
    An external computer monitor is easy. Buy a 24″ Dell 2407 or an Apple 23″ or 30″, they all work.
    Get the SATA external (Firmtek is good), Express 3/4. You can find good deals on SATA drives drives at http://www.newegg.com
    Ed
    [raciere] “I’m looking to set up the following configuration w/ my MacBook Pro, and I’m not quite sure how to do it. Any advice apprecaited.
    ANY adivce appreciated! Thanks for any response. “
  • Craig Alan
    June 22, 2006 at 4:43 am
    Can’t you just connect a firewire cam or deck to the mac and then connect the broadcast monitor to the deck?
    https://www.wiebetech.com/products/silversata.php#pricingavailability
  • Peter Wiggins
    June 22, 2006 at 10:17 am
    Try the Matrox MXO to get a broadcast output from the DVI out of your MBP
    There is a Sata express card that runs at 3Gig for the MBP too.
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Kalunga Lima
    June 22, 2006 at 11:59 am
    A cheap S-video monitoring solution, if you do not want to use a DV deck/camera, is the Datavideo DAC-200 for under $180 (www.datavideo.us). It is the same color as your powerbook pro, and only works if you are editing DV.
    Canopus also makes the ADVC110, which has the advantage of not requiring powersupply (wallwart) if using 6 pin firewire cable. Again DV only.
    These are universal and require no drivers as they function with the firewire standard and have nothing to do with the computer (hence DV/DVCAM only). They both give you the possibility of digitizing analogue (composite) video and unbalanced audio.
    best of luck
