Activity › Forums › Apple OS X › Macbook Pro specs for editing?
  • Macbook Pro specs for editing?
    Posted by Zach Blaesi on June 27, 2011 at 1:13 am
    I personally prefer to use desktops, but since I’m transferring to NYU this summer, I don’t want to lug my desktop right away, and I also want a laptop for taking notes and the increased freedom and mobility. I’m planning to get a 15″ Macbook Pro so I get a balance between size and power, but I’m not sure how crazy I should go when making the purchase. There are options for 2.0, 2.2, or 2.3 GHz; 4GB or 8GB RAM; 750GB Serial ATA Drive @ 5400 rpm, 500GB Serial ATA Drive @ 7200 rpm, 128GB Solid State Drive, 256GB Solid State Drive, or 512GB Solid State Drive; glossy or antiglare screen; and so on.
    I’m trying to stay as close to (or under) $2000 as possible (I should get a $200 student discount), and I’m not sure what specs to select.
    I plan to use the laptop as my primary editing unit for FCP.
    What would you guys recommend?
    Alexander Kallas replied 15 years, 3 months ago 2 Members · 3 Replies
  • Alexander Kallas
    June 27, 2011 at 11:09 am
    Max out your budget, get the most power and RAM that you can afford, and check out the port availability for expansion. You will get more time and versatility from a 17″ MBP.
    Cheers
    Alexander
  • Zach Blaesi
    June 27, 2011 at 11:38 am
    Can you explain to me the pros and cons of 15″ vs. 17″? I’m worried about portability as a college student.
  • Alexander Kallas
    June 27, 2011 at 11:33 pm
    check the Apple website, the 17″ has way more potential.
    Cheers
    Alexander
