Activity Forums Adobe Premiere Pro MacBook Pro Retina HDMI Out
  • MacBook Pro Retina HDMI Out
    Posted by Adam Portnoy on November 8, 2012 at 2:08 pm
    I’m looking to set up a MacBook Pro Retina system with Premiere Pro CS6. Can the HDMI out of the MBPr be used for video previews instead of a Blackmagic/AJA/Matrox box? The idea would be MBPr with Apple Thunderbolt display for OS and HDMI monitor for video preview. Any experience or thoughts?
    Erik Lindahl replied 13 years, 10 months ago 4 Members · 3 Replies
  • Daniel Frome
    November 8, 2012 at 5:22 pm
    It can be used in the same fashion as a displayport/dvi/etc out to a monitor. You should be able to tell Premiere to display a fullscreen image on it.
    The difference with using an AJA/BM/etc card is that, when used with a calibrated rec.709 monitor, you get color accuracy. In the scenario you are describing you would not be seeing TV accurate colors. Although, from what I’ve heard, Premiere’s YUV-to-RGB conversion is very good… so it would be a decent ballpark.
  • Shane Ross
    November 10, 2012 at 7:19 am
    I suggest getting the AJA T-Tap. That connects via Thunderbolt, outputs HDMI and SDI with embedded audio. Bus powered. Sends a proper signal. $300.
    Shane
    Little Frog Post
  • Erik Lindahl
    November 11, 2012 at 11:40 pm
    The T-Tap is great value. Do note it doesn’t support hardware downscale however.
