Activity › Forums › DaVinci Resolve › MacBook pro retina disply 2013
Posted by Matta Roushdy on December 27, 2017 at 10:33 pmDear all,
I need your opinion about MacBook pro
15inch cor i7 2013
I am a film editor and Colorist so is it worth it to buy it
Used with a very good condition.I forgot to tell you my wife is a 3d and 2D animator
Using Maya and Adobe after effectsMatta Roushdy
Charles Haine replied 8 years, 8 months ago 5 Members · 5 Replies -
Shane Ross
December 28, 2017 at 1:09 amI wouldn’t. It’ll barely be able to deal with 1080p…no way will it handle 4K or UHD.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Matta Roushdy
December 28, 2017 at 12:53 pmThank you Shane, if Mac book pro 2015 it will make a different
And I have 2another option imac 27 inch 2013
And old macpro 12 core so what do you think
Thank you for your helpMatta Roushdy
Eric Santiago
December 28, 2017 at 3:23 pmI have used similar with 4K/5K footage but using RED files.
Simple assembly and first light in REDCINE.
It survived a round of Resolve in HD timeline but I have faster workstations 90% of the time.
If this is your main system, I suggest you go a lot higher in speed.
I also work in Maya but that I stick with PCs.
I do use Maya 2018 on my new Mac Pro but for final renders I have to shoot it over to Windows. -
Geoffrey Orthwein
January 3, 2018 at 5:26 amI have used this exact model of MBPro to cut two feature films and grade two (other) features, as well as countless smaller form projects. The first feature was C300, the second was 4K Red RAW. Seamless playback and performance through the entire edit and color grade. I cut both in FCPX, which handles those formats much better than some other platforms. Graded both in DaVinci Resolve. The machine is definitely aging now, but if you can get it on the cheap, no reason to think it couldn’t handle the job.
Charles Haine
January 15, 2018 at 10:50 amHonestly, according to some tests it’s FASTER than the 2015, since the 2015 switched to AMD and the 2013 still ran NVIDIA with the GT750.
I compared a 2016 MBP to a 2013MBP, and prefered the 2013 and returned the 2016.
Great machine, I still work on it daily, it handles 1080p just fine, has graded 5 features (2 of them 4k, though RED not ProRes, 4k ProRes bogs down).
Considering getting an external GPU to keep it going I love it so much.
MagSafe for Lyfe!
CharlesHaineColorist.com
