Activity › Forums › Adobe Premiere Pro › MacBook Pro Retina 13 with Intel Iris graphics breaks Premiere Pro CC hardware output
  • MacBook Pro Retina 13 with Intel Iris graphics breaks Premiere Pro CC hardware output
    Posted by Peter Price on July 6, 2014 at 10:20 am
    Hi all,
    I just recently got a MacBook Pro 13 Retina, to use for basic editing as a secondary system to my iMac. The MacBook Pro sports a Intel Iris integrated graphics system. When I use GPU acceleration (Open CL), my Blackmagic or AJA Thunderbolt I/O outputs solid green. When I switch to software only, video plays back fine.
    I’m running Premiere Pro CC 2014 on Mac OS 10.9.4. I’ve read that Adobe is now optimized for Intel Iris graphics, but why is mine not working when using external video IO?
    Anyone run into this?
    Jorge Alduncin replied 11 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tim Kolb
    July 7, 2014 at 5:11 am
    If the CPU (Mercury Software) engine solves the problem, I would investigate whether Mercury transmit (the system for handing off frames from the GPU to an SDI or Thunderbolt, etc peripheral) might be too demanding for an integrated GPU?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Peter Price
    July 7, 2014 at 5:47 am
    That could be the case. It does seem to work, when I don’t have the AJA or Blackmagic boxes attached. And Adobe does claim it supports Intel Iris GPU’s since CC 2014, according to this: https://helpx.adobe.com/premiere-pro/system-requirements.html#Adobe Premiere Pro CC (2014) system requirements and language versions
    I just found it puzzling that it was happening to both AJA and BMD IO.
  • Tim Kolb
    July 7, 2014 at 12:15 pm
    [Peter Price] “I just found it puzzling that it was happening to both AJA and BMD IO.”
    Actually, that’s what actually points back to the GPU (or maybe just the general configuration of the MBPro) for me…
    Adobe does clearly support the GPU since you get some performance boost when you aren’t handing off frames to an external device.
    Handing off to an external device with GPU-processed frames isn’t a low-resource operation…and it’s a dual core laptop with a 9 hour battery life.
    TimK,
    Kolb Productions,
  • Al Bergstein
    July 7, 2014 at 12:56 pm
    Since the 10.9.4 update just came out and fixed a lot of major video issues for Adobe, I’m wondering if this is related to the update. I would call Adobe tech support and find out if this is a new issue they are seeing, as well as check the Blackmagic and Aja boards here.
    Al
  • Peter Garaway
    July 7, 2014 at 4:40 pm
    Hi Peter,
    Sorry for your troubles. We’re investigating this issue now. The workaround for the time being is disabling OpenCL while outputting to a external monitor via 3rd party hardware.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Jorge Alduncin
    January 30, 2015 at 2:04 am
    Hi, I’ve been having the same problem with the Intel Pro card in my retina mackbook pro.Whenever I want to enable external playback to a monitor, the secondary screen turns white and premiere pro’s playhead won’t play.It says on the bottom alerts that “A low-level exception ocurred in adobe monitor 2” Has this problem been solved?, I just bought adobe’s creative cloud plan and i’m starting to regret it, because it’s been a while since this error hasn’t been attended.
  • Kacper Skowron
    April 1, 2015 at 3:54 pm
    I just got off the phone with adobe and they tell me that intel iris has conflicts with the intel iris and they are working on it. According to the rep, the grafic card is not powerful enough? To me it seems more like a software conflict more than anything else ;(
    He said it might be fixed in the next software update in 3-4 months…
    I hope it helps,
    cheers,
    kacper skowron
    LA based DP
  • Jorge Alduncin
    April 1, 2015 at 5:32 pm
    It is a software issue clearly, finally some made that phonecall.Thank You!!!!!!!!!
