Activity Forums Apple Final Cut Pro Legacy MacBook Pro + RAID harvested from a Mac Pro
  • MacBook Pro + RAID harvested from a Mac Pro
    Posted by Aldo Palumbo on August 26, 2010 at 9:01 am
    I have a Mac Pro with an internal RAID 0 striped across 3 drives. Whilst the Mac Pro is being repaired, I’d like to remove these drives and place them in a drive enclosure attached to my MacBook Pro via a single eSATA cable. Am I right in thinking this is as simple as slotting and plugging?
    The RAID was created using Disk Utility.
    The enclosure I’m poised to purchase is this Icy Dock 4-bay:
    https://www.cremax.com/product/mb561us-4sc.html
    I’m using a Lacie eSATA ExpressCard, which supports port multiplier devices, but I’m wondering if that means it can act as a controller card for the Icy Dock.
    https://www.lacie.com/uk/products/product.htm?pid=11033
    many thanks
    Aldo
    PS (Thank you Shane, Walter et al for ensuring I bought the 17″ MacBook Pro.)
    Aldo Palumbo
    http://www.aldopalumbo.com
    Aldo Palumbo replied 16 years ago 2 Members · 4 Replies
  • Shane Ross
    August 26, 2010 at 9:06 am
    Software raided? So no RAID card? MIGHT be possible. But I haven’t tried it, or heard that it would…so I’d proceed with caution.
    Shane
  • Aldo Palumbo
    August 26, 2010 at 9:23 am
    Many thanks for the quick reply. No, no RAID card. Is a RAID card really necessary for RAID 0? My thinking is that the internal linking inside the Icy Dock can’t be any more or less complicated than what’s inside a Mac Pro: just SATA connections, and that eSATA just continues that connectivity right into a MacBook Pro.
    But as you suggest; who amongst us likes to assume?
    Ultimately, I’d like to have my 3 x 750GB internal RAID 0 mirrored by a 4 x 2TB external RAID 0. I think this document says it’s possible:
    https://support.apple.com/kb/TA24359?viewlocale=en_US
    cheers
    Aldo
    Aldo Palumbo
  • Shane Ross
    August 26, 2010 at 9:32 am
    [Aldo Palumbo] “Is a RAID card really necessary for RAID 0? “
    No…it is necessary for a “hardware RAID,” which is more stable than a software one. That’s all.
    [Aldo Palumbo] “My thinking is that the internal linking inside the Icy Dock can’t be any more or less complicated than what’s inside a Mac Pro: just SATA connections, and that eSATA just continues that connectivity right into a MacBook Pro.”
    I agree in theory. It’s just doing it in PRACTICE that will be nerve wracking. I mean, what if it DOESN”T work? Might loose the info on the drives. Maybe someone has done this. No…wait, I have, sorta. I had 4 drives in an external box, raided as RAID 0. I got a new box, put them in there…worked fine. Both via eSATA. So it should work.
    Shane
  • Aldo Palumbo
    August 26, 2010 at 9:41 am
    Many thanks, Shane. Fingers crossed.
    all the best from Scotland.
    Aldo
    Aldo Palumbo
