Activity Forums Apple Final Cut Pro Legacy Macbook Pro HD Editing
  • Macbook Pro HD Editing
    Posted by Dan Atkinson on October 22, 2008 at 10:33 am
    Hi guys,
    Anyone out there doing any HD editing on a Macbook Pro? My spec is 2.6GHz core 2 duo, 4gb ram, FCS 2. I’m thinking of investing in Matrox MXO 2 but I’m now starting to hear it’s not up to capturing Pro-res through a notebook. That was going to be my preferred workflow – MXO 2 on my express 34 and G-tech G-Raid2 through my FW800. Maybe it’s not possible? But any suggestions are appreciated – and i know the obvious one is invest in a new mac pro but i’m exploring every avenue.
    Gary Bettan replied 17 years, 10 months ago 9 Members · 16 Replies
  • 16 Replies
  • Dan Davis
    October 22, 2008 at 1:03 pm
    I got my MXO2 a couple of weeks ago and for me at the moment it does what
    it says on the tin.
    My Macbook Pro is 2.33 with 2 gig of ram, upping to 3 soon.
    I’ve captured digi in ProRes and on-lined with ease in FCP.
    The HDMI monitor solution works very well on my 720p Panasonic.
    As far as I know at the moment DVCproHD will work with your Mac and a MXO2,
    anything else HD would be pushing your Macs limits.
    Danny.
  • Mustafa Bhagat
    October 22, 2008 at 2:10 pm
    I am doing a project in DVCPRO HD 720p60. I digitized from a 1400A via firewire using my macbook pro (core duo 2.8; 4gig ram) to a glyph drive via FW800.
    worked beautifully. I can playback and edit without any dropped frames at all – even shuttling. I do not have any extra hardware.
    When i work on my Mac Pro – i use the intensity pro to a HD monitor via HDMI – have not fully tested out this system yet though as i am just getting going.
    good luck
    MB
  • Dan Atkinson
    October 22, 2008 at 2:21 pm
    Thanks so far. Has anyone captured non-firewire into mac book pro using some kind of I/O?
  • Chris Poisson
    October 22, 2008 at 3:16 pm
    I edit 108030p ProRes all day long on an MBP 2.4 with 4 gigs of RAM. I only capture via FW though, but it works great. I have a 17″ widescreen for my second monitor, and feed FW through an old deck with component out to a CRT. For storage I use a 2 drawer Firmtec with 1 TB RAID 0. This setup just works.
    Have a wonderful day.
  • Gary Adcock
    October 22, 2008 at 3:38 pm
    [Dan Atkinson] “Has anyone captured non-firewire into mac book pro using some kind of I/O?”
    I work in a variety HD formats using Aja’s IoHD for capture from any SD/HD/ video connection- that means basically anything you will find on a camera or deck for direct video playback -Svideo/ Component, Composite, HDSDI, SDI, and with some caveats even HDMI.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Jeremy Garchow
    October 22, 2008 at 5:05 pm
    I am in the same boat as Gary. The ioHD is an awesome choice and really takes portable editing to a new level. In HD, you will want to work in ProRes or HQ. Get yourself a decent SATA array/enclosure to connect to your Express/34. If you need to use fw800, then you can get a fw800 express/34 card.
    Jeremy
  • Dan Atkinson
    October 22, 2008 at 8:52 pm
    [Chris Poisson] “I edit 108030p ProRes all day long on an MBP 2.4 with 4 gigs of RAM. I only capture via FW though”
    108030p ProRes through firewire? Is this HDV to pro-res at 1440×1080?
    Thanks everyone for the advice. I’d looked into the ioHD and it is an animal. At half the price I was hoping the MXO2 would do something similar but it doesn’t look like it will – funny how it’s sold as portable and advertised working with MBP but doesn’t deliver on everything it states.
  • Chris Poisson
    October 23, 2008 at 6:31 pm
    Yes, it’s 1440×1080 but the GOP format is gone.
  • Matrox_tm_chris Ellis
    October 24, 2008 at 4:21 pm
    Hi Dan,
    The MXO2 can capture ProRes 422 and ProRes 422 HQ SD on laptops. In HD capturing to ProRes on a laptop is not possible right now because of CPU limitations but playing back HD ProRes on a laptop is no problem.
    You might want to take a look at our FAQ to get all the info you need.
    https://matrox.com/video/en/support/mxo2/system/faqs/#faq4
    You can also take a look at our datasheet as well as other information located on this page here at,
    https://matrox.com/video/en/products/mxo2/
    Best Regards,
    Chris.
  • Chris Poisson
    October 24, 2008 at 10:41 pm
    Chris,
    I am capturing 1080 30p ProRes on my laptop as I type, in real time, via FireWire. Do it almost every day.
