Activity Forums Apple Final Cut Pro Legacy MacBook Pro editing system PRE SALES Question – money no option
  • MacBook Pro editing system PRE SALES Question – money no option
    Posted by Kaito Tanno on April 15, 2008 at 4:12 am
    I have the current Macbook Pro 15″ 2.5Ghz.
    I want to input the digibeta project I have in at the highest possible quality and be able to play back on an external monitor (23″ cinema display). What I/O device would suit best? Ideally would like a device that I can use with HD 1080 HDCAM SR projects in the future, this is the only digibeta project I will be handling. I am renting a deck for each project.
    I guess what I am asking is, what is the best set up for editing on a MacBook Pro, external drives (raid?) and I/O device. I want to view at 1080 on all future projects but will not be doing any color corrections at this stage. Also is there any disadvantage quality wise using a MBP as opposed to a MacPro apart from the obvious processing power.
    If someone with experience that has a few minutes perhaps they would also be so kind to list the ideal MacPro editing system.
    Although I listed money is no option, the budget excluding Mac and cinema displays is approx $10K. I want to go shopping. Thank s for your help.
    Kaito Tanno replied 18 years, 5 months ago 2 Members · 2 Replies
  • Walter Biscardi
    April 16, 2008 at 2:43 am
    [Kaito Tanno] “. What I/O device would suit best? Ideally would like a device that I can use with HD 1080 HDCAM SR projects in the future, this is the only digibeta project I will be handling. I am renting a deck for each project.”
    The Io HD, which handles ProRes and DVCPro HD since you can edit uncompressed HD on a MacBook Pro anyway. If you want to edit HDCAM SR projects, especially if they are true 4:4:4, then you need a Mac Pro with an AJA Kona 3 board.
    [Kaito Tanno] “Also is there any disadvantage quality wise using a MBP as opposed to a MacPro apart from the obvious processing power.”
    Yeah, you’re limited to compressed formats only and the renders will be much slower.
    Ideal system is a Mac Pro, AJA Kona 3, very fast SATA array like the MaxxDigital EVO HD model. 500MB/s in RAID 5. And add a proper HD monitor.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Kaito Tanno
    April 22, 2008 at 6:09 am
    Dear Walter
    Thank you for your replay, I have decide to get a Kona 3, Mac Pro 2 x 23″ cinema displays and an AJA HDP connected to a Sony Bravia for playback only.
    I think internal drives will be ok for this digibeta project speed wise. Will add an external raid and Colour correction monitor for the next project.
    Thanks again Kai
