Activity Forums Apple Final Cut Pro Legacy Macbook Pro + Cinema Display + Seagate Go Flex = heat
  • Macbook Pro + Cinema Display + Seagate Go Flex = heat
    Posted by Cassie Chappell on September 4, 2012 at 9:04 am
    Hi folks,
    I’m editing a project on FCP 7 with Macbook Pro using Cinema Display as the exterior monitor. The MBP sits on a Targus fan mat. The video is housed on a Seagate drive. Recently I began noticing extra heat (on the upper left) and an increased whirring sound. I unplugged the Targus to confirm that it was the MBP making the whirring noise.
    Experimenting now w/ wireless keyboard & clamshell mode, leaving the laptop slightly open to aid ventilation. Still getting the heat & whirring especially during renders. I’ll be getting an exterior trackpad as well to see if that helps.
    Any input from folks in similar territory would be most humbly appreciated. thanks 🙂
    Bill Celnick replied 14 years ago 2 Members · 1 Reply
  • Bill Celnick
    September 4, 2012 at 10:54 am
    Hopefully your situation is not the same, but the last time I experienced a heat build up and very active fan – on a 14 month old Seagate Barracuda, the drive failed very soon after.
    Be extra diligent with your back-ups while trying to figure this out.
    Good luck.
