Activity Forums Adobe After Effects Macbook Pro 17 hours to render basic video!! How does an 8 core Mac Pro compare to the 12 core?
  • Macbook Pro 17 hours to render basic video!! How does an 8 core Mac Pro compare to the 12 core?
    Posted by Scott Green on April 19, 2012 at 9:48 am
    I’ve been really stressed out that my good old Macbook Pro with 4GB of RAM is no longer adequate for working with After Effects and I desperately need to upgrade. At one point a simple 3 minute video with basic ‘CC glass’ and ‘Sharpen’ effects said 174 hours to render!
    I understand that the 12 Core Mac Pro would be faster that the 8 Core, but the extra cost would be an issue, I’m in two minds whether to go for the 8 Core and save up for a while longer and get the 12 Core. Can anyone offer any advice?
    Also, this is the spec that I added to the basket to work the price out, does this spec look OK to start off with? I know that I can add to and upgrade in the future should I need to like adding more RAM etc., is it possible to upgrade from 8 Cores to 12 Cores?
    Thank you in advance 🙂
    Scott Green replied 14 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Eric Santiago
    April 19, 2012 at 3:26 pm
    More than enough for any high-end needs but later add more RAM and a SAS or extra SSD hard-drive for working files.
    Im more curious as to what your rendering to get those numbers?
    Do you have the NightFlight test file?
    If you can download that, render and post our times.
    There could be something wrong with your file or your system.
  • Nurbek Sagynbaev
    April 19, 2012 at 4:23 pm
    I would wait a couple of more weeks and see if Apple announces new SandyBridge Xeon bases Mac Pros.
  • Jon Bagge
    April 19, 2012 at 7:58 pm
    For a new 8-core machine I’d say 16gig RAM is minimum. For a 12-core I’d say 24gig minimum, but ideally 32 or 48. (32 might be max on a macpro?)
    That might just make the 12-core out of your budget. Personally I’d see what 32gig RAM on an 8-core would cost first. If you still have money to spare, go for the 12-core. (remember not to buy your RAM from Apple…)
    I have 48gig on my 8-core PC. After effects will happily use ALL of it, although how much benefit I’m getting from having 48 rather than 32 I don’t really know.
    As someone else mentioned, the Macpro’s are getting old now, and nobody knows what Apple will do next. Intel has released 8-core chips now, and HP are selling 16-core workstations….
    https://www.jonbagge.net
    Jon Bagge – Editor – London, UK
    Avid – FCP – After Effects
  • Scott Green
    April 20, 2012 at 1:04 pm
    When I turn it on I get a message saying ‘Insufficient RAM, multiprocessing is disabled’, so it’s impossible for me to turn multiprocessing on anyway 🙂
    I really do love good design – https://www.splurj.com
  • Scott Green
    April 20, 2012 at 1:07 pm
    That’s a good point about not buying RAM from Apple, maybe I should get separate costs for RAM from somewhere else. What type of RAM would I look for?
    The Mac Pro support up to 64GB RAM, the option was there when I was working out the prices.
    Thanks.
  • Scott Green
    April 20, 2012 at 1:14 pm
    I think that the main source of the problem was that the original Quicktime file that I imported (4GB is size) was used multiple times within the same composition, although I had trimmed down each instance of the file.
    I also duplicated the same adjustment layer multiple times (approx 40 or even 50 times), also trimmed to the length I required, with Twitch effects on.
    Plus, a few instances of a Lens Blur effects, only short instances with a layer mark and opacity flashes on them.
    Plus an overall CC Glass and Sharpen effect, which I turned off for the render.
    Which one of these do you think was the main cause?
    No I’ve never heard of NightFlight, what’s that? My Google search only gave me results for a nightclub in Moscow 🙂
  • Scott Green
    April 23, 2012 at 11:00 am
    No I didn’t know that, I can’t find the setting either?
  • Scott Green
    April 24, 2012 at 9:35 am
    Hi Dave, can you tell me where this setting is to only render the effects that you’ve applied please? It would be very useful to know, thanks.
  • Scott Green
    April 24, 2012 at 3:34 pm
    This page on Improving After Effects performance is very useful:
    https://help.adobe.com/en_US/aftereffects/cs/using/WSF13D6BED-C53B-408a-B2D6-C8B4205D4FB7a.html
    Thanks.
