Activity Forums Storage & Archiving Macbook Buying Advice
  • Macbook Buying Advice
    Posted by Jacob Holcomb on March 15, 2018 at 4:35 am
    I have a small budget (<$1500) for a Macbook or Macbook Pro. Goal is to get something to backup footage from a GH5 on a remote/international shoot.
    I was in love the form factor of the Macbook 12″ but only has one USB-C port and apparently it doesn’t have enough juice to push two portable drives on it’s own.
    2017 Macbook Pro 13″ is the same price but has two Thunderbolt 3 ports that push 15 and 7 watts respectively. There are so many adapters and drives that it’s making my head spin, but I figure 2 ports means there’s less likely to go wrong. Also the faster processor means faster transfers when making backups to a second drive.
    Anybody have recommendations on what adapters and drives to use?
    Thank you
    Tim Gerhard replied 8 years, 6 months ago 3 Members · 2 Replies
  • Martin Greenwood
    March 22, 2018 at 3:53 pm
    For on set workflow get the MacBook Pro. The ports support Thunderbolt 3 and USB-C so give you a lot more flexibility. There are Thunderbolt camera card readers that you may want to use. Also Thunderbolt 3 RAID’s.
    Also the MBP has better processor performance.
    Martin
    CTO
    YoYotta.com
  • Tim Gerhard
    March 22, 2018 at 6:44 pm
    Definitely just get the Macbook Pro w/ 2x TB3 ports. TB3 ports are the same as USB-C so just get some external drives that are USB-C or TB3. If you’re using external hard drives USB-C is sufficient without the need for Thunderbolt speeds.
    I recommend G-Tech for external drives. I’m a G-Tech dealer, so I can price them out if you tell me what capacity you need.
    Tim Gerhard
    MagStor Inc.
    614-505-6333
    tgerhard@magnext.com
    NAB 2018 Booth #SL15816
