Activity › Forums › Compression Techniques › Mac x264Encoder.component crashes
  • Mac x264Encoder.component crashes
    Posted by Olive Green on April 28, 2009 at 12:03 pm
    I recently downloaded the x264Encoder.component version 1.0.1 from mac’s website.
    I am trying to use it to export as a H264 Quicktime Movie from FCP (PAL) using Quicktime Converision.
    In the Video Compression Settings window:
    – I adjust the frame rate to 24fps
    – I adjust Key Frames to automatic
    – I set data rate to automatic
    – I set encoding to single pass (medium)
    Then I click on the options button which opens the Libavcodec settings window. As soon as I change anything in this window (or even if I click OK to the default settings in this window) fcp will crash – not straight away, but as soon as I ok the video compression settings.
    If I don’t use these options (libavcodec settings) I can export without any problems using x264.
    The problem is that I need to be able to set the Container Level Colour Adjustment to 5-1-6 Composite Pal/Digital 625 as I believe this will help my video to be viewed correctly over the inernet.
    Does anyone know what my problem is? Can anyone take a rough guess? Any help at all would be appreciated as this is becoming very frustrating.
    By the way, I am using FCP 5.0.4 and Quicktime 7.6 (not QT pro – Does this make a difference?)
    Daniel Low replied 17 years, 5 months ago 2 Members · 1 Reply
  • Daniel Low
    April 28, 2009 at 1:38 pm
    [Olive Green] “I recently downloaded the x264Encoder.component version 1.0.1 from mac’s website.”
    From where?
    [Olive Green] “I adjust the frame rate to 24fps”
    Why adjust down from 25fps?
    [Olive Green] “- I set data rate to automatic”
    You DO NOT want to do that.
    [Olive Green] “The problem is that I need to be able to set the Container Level Colour Adjustment to 5-1-6 Composite Pal/Digital 625 as I believe this will help my video to be viewed correctly over the inernet.”
    Who told you that?
    You might want to have a look at some other applications to do the Job:
    Handbrake – https://handbrake.fr/?article=download
    and
    Xdot – https://xdot.command-q.org/
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
