Activity Forums Adobe InDesign MAC to PC
  • Russ Blaise
    April 1, 2012 at 5:04 pm
    I’m guessing that you have InDesign installed on the PC? The only real problem you might run into is that your fonts might not match. If you are using OpenType fonts (otf), and they are installed on both computers, there shouldn’t be a problem. If you are using Postscript, and True Type, that’s where the problems come into play. If that’s the case, you could convert your fonts to otf using a program like, “FontXChange”. https://www.fontgear.net/fontxchange.html
