Activity › Forums › Apple Final Cut Pro › Mac Studio: 32GB or 64GB?
  • Kirk Pitts
    May 20, 2022 at 12:14 am
    I am interested in the answers to this also. I am thinking about the gpu upgrade also. Are you, Ken?
  • Ken Bennett
    May 20, 2022 at 12:28 am
    No. I’m OK with the M1 Max. But I’m getting it with a 2TB SSD. Just trying to justify upgrading to 64GB.
  • W thomas Leroux
    May 20, 2022 at 1:10 am
    It depends how you use your Mac, to be honest. Most “regular” users won’t eat up all the ram. That said, if you’re running a tonne of software, browser tabs, and other apps at the same time, the more ram the better. If you’re using Motion, it can chew up memory too. When memory gets filled up (I’m simplifying), macOS writes some of it to the internal SSD to free some up for whatever needs it now, this does (slightly) slow down performance.
    Cons: $400. If the extra money isn’t going to break the bank, I’d recommend it.
  • Ken Bennett
    May 20, 2022 at 2:51 am
    On my current iMac when I run FCPX or Motion I usually shut down the web browser. I edit 4K video and all video source is from an external RAID. My iMac is 9 years old so I plan on hanging on to the new Mac Studio for probably that long.
  • Eric Santiago
    May 20, 2022 at 4:19 am
    If you cant upgrade the RAM on these then I would suggest it.
    You can always buy external RAID drives after.
