Activity Forums Apple OS X Mac Question
  • Mac Question
    Posted by Greg Ball on March 25, 2015 at 8:10 pm
    I have a MacPro5,1 2.4GHz Quad-Core Intel Xeon with 16GB of memory. I edit on FCP
    Since USB3.0 seems like one of the newest ways of editing and using G-raid drives, I’m wondering how I can go about adding USB 3.0 to this mac.
    I understand that I can install a USB 3.0 card into the mac, but I already have a ESATA card installed.
    I believe I can add a second card (USB3.0) to the computer. Is that so? Will that cause conflicts with the ESATA card?
    Should that create good read/write speeds to a USB 3.0 7200rmp external drive?
    Any help would be appreciated. Thanks.
    John Rofrano replied 11 years, 5 months ago 2 Members · 1 Reply
  • John Rofrano
    March 29, 2015 at 7:16 pm
    [Greg Ball] “Since USB3.0 seems like one of the newest ways of editing and using G-raid drives, I’m wondering how I can go about adding USB 3.0 to this mac.”
    I also have a MacPro 5,1 and I purchased this USB 3.0 card and I’m very happy with it:
    Inateck 4 Ports PCI-E to USB 3.0 Expansion Card for Mac Pro
    [Greg Ball] “I understand that I can install a USB 3.0 card into the mac, but I already have a ESATA card installed. I believe I can add a second card (USB3.0) to the computer. Is that so? Will that cause conflicts with the ESATA card?”
    I shouldn’t. I have an eSATA card as well and they both work great. There are four (4) slots in the MacPro 5,1.
    This is what I have in mine:
    Slot 1: ATI Radeon HD 5870
    Slot 2: 480GB OWC Mercury Accelsior_E2 PCI Express SSD with 2 eSATA ports.
    Slot 3: Inateck 4 Ports PCI-E to USB 3.0 Expansion Card for Mac Pro
    Slot 4: Apple Mac Pro RAID Card
    As long as you have an open slot to put the USB 3.0 card in you should be fine.
    [Greg Ball] “Should that create good read/write speeds to a USB 3.0 7200rmp external drive?”
    Using BMD’s Disk Speed Test I’m getting 86MB/s Write and 90 MB/s Read from my USB 3.0 G-DRIVE single disk. It’s more than enough for the HD work I do with FCP X.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
