Activity › Forums › Storage & Archiving › Mac Pros with QLogic 7.4.0.16 Firmware, Stacking QLogic 5602 and 5800
  • Mac Pros with QLogic 7.4.0.16 Firmware, Stacking QLogic 5602 and 5800
    Posted by Ben Cheng on July 6, 2010 at 9:34 am
    I like to seek advice from fellow QLogic FC switch users.
    Wonder if you encounter any issue connecting Mac Pros (with Apple/LSI FC HBAs and Mac OS X 10.5.x) to QLogic FC switches with 7.4.0.16 firmware?
    Another question is about stacking 2 existing QLogic 5602 to 1 new QLogic 5800V.
    The 2 existing QLogic 5602 are running firmware 5.0.1.10.0, while the new QLogic 5800V is running 7.4.0.16 or earlier.
    Should I update the existing QLogic 5602 to the same firmware as the 5800V?
    I read in QLogic forum, it’s recommended to update to 6.8.0.03 first, then to 7.4.0.16.
    Wonder if you have any similar experience?
    Cheers,
    Ben Cheng · Application Engineer · The Media Village Pte Ltd
    Ben Cheng replied 16 years, 2 months ago 2 Members · 2 Replies
  • Juan Salvo
    July 6, 2010 at 6:34 pm
    No issues. Works well.
    If you want to stack, then they should all be on the same firmware.
    This is recommended only if you need to do a hot upgrade (without losing any connectivity). If you can do a reset on teh switches (meaning take the san down, update firmware, restart switches, bring san back up) then you can go straight from 5.x to 7.4.0.16. This is what we did and it’s all working very well, qlogic is very solid.
  • Ben Cheng
    July 7, 2010 at 8:31 am
    Hi, thanks for your reply!
    Cheers,
