Activity › Forums › Apple Final Cut Pro Legacy › Mac Pro Raid Card Config
  • Mac Pro Raid Card Config
    Posted by Peter Tours on June 23, 2010 at 12:14 am
    I have a question about the configuration of my drives with the Mac Pro Raid Card (2009). I currently have bay 1 as my system drive and bays 2-4 as Raid 0 (yes I back up constantly).
    In disc utility I see both the system drive and the “raid” as separate “drives” but I am wondering if by using the raid card I am actually imitating a config like having just one drive for apps and media because it’s all coming thru the card??
    I edit DVC PRO HD 720 24p and the puter can really get boggy which made me consider this as a possible bad config.
    I am considering trying the system drive in an optical bay. Does anyone have an opinion on this?
    It sure seems like my system is very “boggy” but I really have no benchmark – except my old Media 100 system ran a lot smoother back in the day….
    2009 Mac Pro Octo 2.93
    OS 10.5.8
    FCS 3 FCP 7.0.2
    12gb Ram
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    Peter Tours replied 16 years, 3 months ago 3 Members · 3 Replies
  • Shane Ross
    June 23, 2010 at 12:42 am
    [peter tours] “In disc utility I see both the system drive and the “raid” as separate “drives” but I am wondering if by using the raid card I am actually imitating a config like having just one drive for apps and media because it’s all coming thru the card?? “
    If the Disk Utility sees them as separate, then they are separate. If the system drive is not part of the Raid, it is separate.
    [peter tours] “I am considering trying the system drive in an optical bay. Does anyone have an opinion on this?”
    That’s where mine is. Leaving all 4 bays for other drives. But I don’t have the RAID card.
    [peter tours] “It sure seems like my system is very “boggy” but I really have no benchmark – except my old Media 100 system ran a lot smoother back in the day…. “
    Run the AJA SPEED TEST on the RAID. Free at AJA.com. And how full is the raid? They start bogging down at 80% full.
    Shane
  • Jason Brown
    June 23, 2010 at 2:34 am
    I had an interesting situation that may or may not be applicable in this case. I had a raid card, and a raid 0 (backed up as well) and I swapped out my video card and my raid was gone. I fiddled with it for a long time and came to terms that I had lost data. I had one last thought, pulled out my raid card and the raid was back online. Turned out that I had set up a software raid and apparently when I swapped out the video card it initialized the raid card? It was bizarre, but I did have a raid card in my machine with a software raid running.
  • Peter Tours
    June 23, 2010 at 3:54 pm
    Shane – I have a Kona LHe so I already had the utility. Here are the results using DVCPRO HD 720p60 frame size:
    File Size Sweep
    MB MB/sec
    • Read Write
    • 128.0 204.3 203.4
    • 256.0 199.3 165.1
    • 512.0 183.5 166.4
    • 1024.0 192.5 176.8
    • 2048.0 193.3 181.0
    • 4096.0 196.1 174.0
    • 8192.0 196.6 178.0
    • 16384.0 197.3 177.9
    I am having trouble formatting it for the cow. but the first column is file size, then next to it read speed followed by write speed.
    Clearly better than 100mb/s required for DVCPRO HD but nowhere near 300mb/s rating – but certainly more than adequate.
    Peter Tours
    Fort Lauderdale, FL
