Activity Forums Apple Final Cut Pro Legacy Mac Pro Graphics upgrade
  • Mac Pro Graphics upgrade
    Posted by Bruce Stubblefield on October 28, 2008 at 6:37 pm
    Hello,
    Running FCS2 on an 8-core 2.8 GHZ with two HD 2600 XT cards. Cutting a feature in Pro Res HQ 2048 x 1024 files. We get a lot of “can’t render with this video card” type messages and think we need a more powerful card. Have been told there’s problems running two cards in one machine, but removing one of them doesn’t affect the problem.
    I see a lot of negative posts about the NVIDIA GeForce 8800 GT for use with FCS2, but this is the card that Apple pushes on their upgrade page.
    We don’t need Kona-type HD output, just the right graphics card that can handle 2048 x 1024 files with titles and various VFX elements to many shots. Can anyone recommend the best card or best value solution for this issue?
    thanks
    Bruce S
    Jeremy Garchow replied 17 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Steve Eisen
    October 28, 2008 at 7:06 pm
    Do you have an HD capture card?
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jeremy Garchow
    October 28, 2008 at 7:13 pm
    The two cards in one mahcine can’t help, but also I’d imagine that whatever plug in your are uisng to render graphics can’t extend beyond a 1K geometry. That’d be my first guess.
    Jeremy
  • Bruce Stubblefield
    October 28, 2008 at 7:25 pm
    No HD capture card.
    thanks
  • Peter Wiggins
    October 28, 2008 at 7:51 pm
    Bruce,
    FCP is pretty rubbish when it comes to management of video memory, you probably got something like this:
    “Can’t render at the requested size and depth”
    There are two ways round this which I have to give Gabriele at Noise Industries the credit for:-
    1) Save your project, quit and re-launch Final Cut Pro. More often than not, Final Cut Pro will render the sequence on a fresh start.
    2) Make sure that you are rendering in 8-bit YUV:
    – Open the Sequence Settings window and switch to the Video Processing tab
    – Select the “Render in 8-bit YUV” option
    Hope that helps
    Peter
    October 28, 2008 at 8:58 pm
    thanks,
    apparently we’re already using those settings, and restarts have no effect.
    Bruce S
  • Peter Wiggins
    October 29, 2008 at 1:41 am
    OK, not the answer you wanted, but can you render in chunks and then reassemble?
    Peter
  • Jeremy Garchow
    October 29, 2008 at 3:01 am
    Also, can you do me a favor and copy and paste your timeline into a 1920×1080 timeline and see if it renders. Please? Just for a goof?
    Jeremy
