Activity Forums Storage & Archiving Mac Pro expanded for storage and PCIe slot
  • Mac Pro expanded for storage and PCIe slot
    Posted by Jeffrey Schwartz on September 21, 2010 at 6:00 am
    I work on video content creation with my Mac Pro (2.8 GHz Quad-Core; 4 GB of main memory). Due to heavy requirements for video capacity, mass storage are needed. Recently, I found Netstor NA380A providing the solution.
    You may see it here:
    https://www.netstor.com.tw/_03/03_02.php?ODM=#
    The NA380A provides 24 disk bays. Now 12 of the bays are installed with 1.5 TB hard disks, and the other 12 of them with 1 TB ones, so the sum is 30 TB which I can use. Furthermore, I acquired an AJA KONA LHe card from a friend, but all the three PCIe slots are occupied on my Mac Pro. Thanks NA380A for its circumspect design, the NA380A provides two PCIe x8 and four PCIe x4 slots, so I can install the KONA LHe card on NA380A’s slot to work with my Mac Pro.
    The NA380A provides both mass storage and PCIe slots for my Mac Pro to make me work on video content creation.
    Jeffrey Schwartz replied 15 years, 11 months ago 3 Members · 5 Replies
  • Bob Zelin
    September 21, 2010 at 5:38 pm
    very nice box Jeff, similar to the JMR solution with PCIe slots in it.
    What does this have to do with SAN networks ?
    bob Zelin
  • Eric Hansen
    September 21, 2010 at 9:30 pm
    i’m a bit confused by PCIe expansion. the way i understand it, the Mac Pros have 40 PCIe lanes (slots 1 and 2 are 16x and 3 and 4 are 4x). this particular unit comes with an 8 lane card, which goes into the Mac’s 16 lane slot. it then offers 2 8x slots or 4 4x slots in expansion, while also driving hard drives? but it says its host card is only 8x. where do the extra lanes come from?
    e
    Eric Hansen – http://www.erichansen.tv
  • Jeffrey Schwartz
    September 27, 2010 at 7:22 am
    Hi Bob,
    Sorry, I wanted to share my experience of the expansion of my Mac Pro for storage and PCIe slot. I visited the Forums at Creative COW, but I wasn’t sure in which forum I should leave my message. Could you please let me know which forum is more appropriate for the message at Creative COW? Thank you so much.
    For Eric,
    As I know, the Netstor NA380A has a built-in slot expansion chipset that allows PCIe lanes to be expanded.
    I installed my AJA KONA LHe card on one of the two PCIe x8 slots on NA380A, so there remains one PCIe x8 slot and four PCIe x4 slots on NA380A. So far as I know, the NA380A comes with an 8 lane card providing a transmission rate of 20 Gbps. The 20 Gbps data rate provided is enough for the KONA LHe card while also driving hard drives. As I know, even two more PCIe cards are added on the remaining PCIe slots on NA380A, the total throughput of the current KONA LHe, the other two PCIe cards, and the driving of hard drives won’t be over 20 Gbps because the x8 slots and the x4 slots are only the specification itself. The things that matter are the actual throughput of each PCIe card you use, so, as I know, even three PCIe cards on NA380A while also driving hard drives are fine with the 8 lane transmission rate 20 Gbps provided by NA380A.
  • Eric Hansen
    September 28, 2010 at 4:28 pm
    hey jeff
    this is probably the most appropriate forum for your post. we’re the guys that deal with MASSIVE storage and this box fits right in.
    so the number of lanes don’t matter so much as the total bandwidth of the source? does this mean that a 8x slot does 20Gbps? would a 16x slot do 40Gbps? sorry for all the questions. i don’t really understand the PCIe structure of the Mac Pro, and now i’m dealing with things like ProTools HD3 and specing out a DaVinci Resolve system and i’m running out of slots so i’m looking at these devices.
    btw, the Kona LHe card is 4x, if you ever need to move slots.
    e
  • Jeffrey Schwartz
    October 1, 2010 at 5:28 am
    Hi Eric,
    Yes, you’re right. The number of lanes don’t matter, as long as the total bandwidth of the source is within 20 Gbps. (a x8 slot does 20 Gbps and a x16 slot does 40 Gbps in PCIe 1.0 spec.) I ever wrote an e-mail to Netstor’s FAE, and he says when a PCIe x8 (8 lanes) RAID card of Areca ARC-1680ix-24 is installed on NA380A, the performance for 24 SATA HDDs is 10 Gbps (1000 MB/s), so we can even plug more PCIe cards on NA380A for the rest 10 Gbps.
    The Pro Tools HD 3 you’re using is x1. I saw a user’s review on PCIe expansion from UAD forums, and his UAD-2 Duo DSP accelerator card with x1, similar to your Pro Tools HD 3, works perfectly between Netstor’s TurboBox and a Laptop with only x1 bandwidth. Therefore, I suppose the rest bandwidth of NA380A should be fairly enough for Pro Tools HD3, and maybe you can install many pieces of Pro Tools HD3.
    https://studionu.com/uadforums/viewtopic.php?f=2&t=14185
    The FAE also says Netstor will release new 16-drive and 24-drive RAID storage system in PCIe 2.0 spec in first quarter of 2011, so the bandwidth will double then.
    Jeff
