Activity Forums Boris FX Particle Illusion Mac OSX install problems
  • Mac OSX install problems
    Posted by Jorge Marsal on February 22, 2008 at 9:50 pm
    I have the similar problems as an earlier post.
    The Default.il3 will not open and crashes the program.
    I trashed all the files as instructed in the first response, shutdown, downloaded a second pkg, reinstalled and the same thing occurs.
    The Help files also do not open.
    The Default file’s info reads as a Unix executable.
    The additional libraries seem to function fine.
    Do I have the right download, etc.
    I don’t believe its a problem with my MacBook Pro 10.4.11.
    Thanks for any and all help.
    Jorge
    Paolo Ciccone replied 18 years, 6 months ago 2 Members · 4 Replies
  • Paolo Ciccone
    February 23, 2008 at 4:48 pm
    This is a problem with the permission flags. It seems that the installer can default to a different user’s permissions if multiple users are installed on your machine.
    After you install PI open the Terminal, go to the folder where PI is installed, usually /Application/particleIllusion 3.0 and run the following commands:
    – sudo bash
    at the prompt enter your usual password
    – chmod -R your_user_name *
    your_user_name is of courser your user name (short version)
    – chgrp -R staff *
    – exit
    That should fix it.
  • Jorge Marsal
    February 23, 2008 at 8:57 pm
    Paolo,
    Thank you for your response.
    I have tried your action several times with no success.
    Not sure if I’m doing something wrong in the command prompts, but I have checked 4 times. I restarted after the process…no success. ???
    Thanks.
  • Jorge Marsal
    February 23, 2008 at 9:07 pm
    Paolo,
    I found an easier route:
    In the info of the particleIllusions 3.0 folder my IT manager’s name was being used as the owner. I changed it to mine and applied to enclosed files.
    All worked after that.
    Jorge
  • Paolo Ciccone
    February 23, 2008 at 11:54 pm
    Yes, that’s exactly the reason why it didn’t work. The chown (change owner) command changes the ownership of the files. Glad you found a solution.
