Activity › Forums › Adobe After Effects Expressions › Mac OSX Dock Genie Effect…
Posted by James Choi on February 11, 2009 at 1:59 amI’ve been doing a lot of searching on CC but have not found a proper way to create the genie effect. The magnifying part of it I’ve managed to figure out but not the positioning part of it.
Rafael Braz replied 6 years, 9 months ago 6 Members · 5 Replies -
Filip Vandueren
February 11, 2009 at 12:43 pmHi James,
I’ve been trying to tackle this.
The thing is that the Genie effect does a couple of things at once:
Hold shift while you minimize a window, and it will do it in slow-motion.
The hardest part is, that as soon as the warped window hits the dock, the dock starts to draw the small icon bottom to top: this is not a side effect of warping the window: it is a separate layer that is being drawn. The Warped layer actually never changes height: it’s masked by the dock. When you maximize, you see that the icon suddenly disappears and the reverse warp starts.That being said. I did an effect that, apart from that icon drawing, looks very similar to the genie.
It uses “Bezier Warp” with expressions for every parameter.Here you can see the bezier warp in action:
First, a “guide-layer” has to be animated with a start position and an end-position for scale and position.
The Bezier Warp then bases itself on those keyframes and using a bunch of different ease-functions, warps the window.Again: not entirely the same as Mac Os, but hopefully close enough.
Tweaking the ease-functions of the four vertex points gives a lot of variation.This is what it looks like with a photo:
Here’s how to do it.
- Download my animation preset: Genie.ffx
- create a comp with your ‘genie’-layer.
- duplicate the layer and call it “Genie Guide” (hide the first layer for now)
- set a keyframe for Position and Scale : this is the start (maximized) position.
- a bit further in the timeline, set 2 new keyframes for Position and Scale: this is the minimized position ‘in the dock’
- hide your “Genie Guide” layer.
- re-activate and show your original layer.
- apply the animation preset “Genie.ffx” to it.
- in the effect’s controls, under “Guide Layer” choose your “Genie Guide” from the pop-up.
- animate the “Genie_time” slider between 0(maximized) and 1(minimized) (there are already grow and shrink keyframes in the ffx)
that’s it.
John Grainge
January 2, 2010 at 3:44 pmHi Filip, great response, I am absolutely deperate to create this effect somehow. Do you know where else I can get your genie.ffx preset as the link has expired I think? Many thanks. keep up the good work.
John
Jp Pelc
June 6, 2016 at 3:43 pmHow did you get the genie.ffx file? The link gives me a 403 forbidden error
Rafael Braz
December 7, 2019 at 1:09 amhey! would you mind uploading the ffx again? ☺
or send me by e-mail… rafaelbraz7@gmail.com
