Activity Forums Media 100 Mac OS upgrade and stability
  • Mac OS upgrade and stability
    Posted by Ted Joyce on July 2, 2005 at 4:59 pm
    I am running a Media 100 8.2.2 XR system on a MacG4 1.4DP under OS 10.3.4 and it is very stable. How high can I safely go OS 10.3.7? ?
    Floh Peters replied 21 years, 2 months ago 3 Members · 3 Replies
  • Ted Joyce
    July 2, 2005 at 6:16 pm
    After belatedly reading posts below it appears I need to have a dual boot capablility.
    Can I just install the latest Mac OS on a large external firewire drive, install Final Cut Express HD on it and designate that my boot drive? Would this work and still leave my M100 system as is?
    I don’t want to have to repartition my internal boot drive into two partitions and install everything again into both just to experiment with HDV and Final Cut Express HD. I understand that my SCSI card & Drive arrays might not work properly with this arrangement but if I booted with them turned off might I expect success?
  • Kieran Matthew
    July 3, 2005 at 1:26 pm
    I am running Media 100 8.2.2 XS on a G4 1.4DP under 10.3.9 and have had no problems whatsoever (OS-wise anyway). Personally, I have always upgraded the OS as soon as it comes from apple and, again, have never had problems – though I always wait until the current project I’m doing finishes before doing so.
    Many people on the list have already moved to Tiger and report no problems either.
    Hope this helps!
  • Floh Peters
    July 4, 2005 at 12:34 pm
    [Ted Joyce] “Can I just install the latest Mac OS on a large external firewire drive, install Final Cut Express HD on it and designate that my boot drive? Would this work and still leave my M100 system as is? “
    Yes, no problem with that.
    [Ted Joyce] “understand that my SCSI card & Drive arrays might not work properly with this arrangement but if I booted with them turned off might I expect success?”
    There should be no problems with that. But I would install at least the latest drivers for your SCSI card (even if you leave the drives turned off), since you don
