Activity Forums Apple OS X mac os extended journaled
  • mac os extended journaled
    Posted by Johnsabbath D’urzo on August 4, 2012 at 2:19 pm
    Just bout a Seagate Expansion Desktop drive 2TB. It’s a USB 3.0 and it also works as a 2.0. I’m using a G5 PowerPC Quad Core. When I format the drive the drive disappears from the desk top, seams like it wont let me format it using extended journaled. When I format it using Ms-dos (fat) they formating works fine. But when I go to copy large files I get a error 0. Is this a problem with the drive? does anyone have this drive or would it be something with the OS 10.5.8?
    Thanks for your help 🙂
    Steve Modica replied 13 years, 11 months ago 4 Members · 3 Replies
  • Craig Alan
    August 4, 2012 at 4:44 pm
    I would try two things.
    Repair permissions.
    Check if disc utility sees the drive (formatted as os extended). If it does, click the mount button. I find some times disc utility sees a drive I want to mount that finder does not. Works for un-mounting too.
    MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Panasonic AG-HPX170, Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
  • Josh Parsley
    August 6, 2012 at 7:34 pm
    I’m not sure about the extended journaled problem but FAT has file size limitations. I imagine you’re transferring files larger than it can handle. I don’t know what FAT format you are using but if you look at that and google “FATXX file size limitations” (XX is the FAT you’re using) it should tell you.
  • Steve Modica
    October 27, 2012 at 12:38 pm
    open a terminal and run the following:
    $ sudo tail -f /var/log/kernel.log
    Try to partition the drive again as HFS/journaled. I’m guessing something useful will pop out on the terminal.
    When done, hit control-C in the terminal and post the messages.
    Steve
    Steve Modica
    CTO, Small Tree Communications
