Activity Forums Apple Final Cut Pro Legacy mac mini uses, suggestions
  • mac mini uses, suggestions
    Posted by Chris Gorman on November 9, 2009 at 6:51 pm
    Any opinions/suggestions? I need to get some inexpensive piece of hardware to use for displaying my HD h.264 video demos at vendor shows on my Apple 23″ HD Cinema Display.
    I did one show borrowing my friend’s mac mini (slightly older version), and it looks great and played out the HD fine.
    So now I’m thinking about buying a mac mini, maybe the new one, to use for future shows. Even the $600 bucks is a stretch now, but if it’s the only reasonable solution, I’ll do it.
    I don’t want to play DVDs because currently I’m not set up to do Blu-ray and want to avoid the quality hit that happens with Std.Def DVD.
    Maybe there’s other uses for the Mac Mini, so that I could get added benefit from the investment. Suggestions?
    Currently (see my specs), I’m running fcp suite on my old pre-Intel G5 2.3 SP, Tiger, and wouldn’t mind being able to offload even a bit of that work load to the mini. What do you think?
    PowerPC G5 DP2.3, 4GB DDR SDRAM, ATI X800XT, OSX.4.11, QT 7.5.5, FCStudio2, FCP 6.0.5 Sonnet 5 Bay SATA (RAID or JBOD as needed), ACD 23″ & Sony NTSC Monitor via Matrox v.1
    Sony ZIU hdv, edit w.ProRes
    Alan Okey replied 16 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    November 9, 2009 at 6:56 pm
    I use mine as my media center, connected to my TV. Hulu…movies…over the air TV with the Elgato EyeTV. MIght also use it to compress things to h.264, but it will be slower than other machines.
    Shane
  • Mark Raudonis
    November 9, 2009 at 7:58 pm
    You may not need an iMac to do this. I was at a tradeshow last week and they were playing back FULL HD 3D sequences off of this:
    https://www.amazon.com/Western-Digital-WD-Media-Player/dp/B001JZFQU4/ref=sr_1_1?ie=UTF8&s=electronics&qid=1257796459&sr=8-1
    Looked great. (This was in the Panasonic Booth… not some dinky little fly by night operation).
    I was impressed.
    Mark
  • Alan Okey
    November 9, 2009 at 11:52 pm
    You could use Qmaster to set up a distributed rendering cluster for Compressor. I wouldn’t be surprised if the new Mini is faster than your G5 when it comes to pure CPU grunt – the bottleneck in the Mini is more likely to be hard drive speed or RAM than CPU speed.
    In any case, you could set up a cluster using Qmaster and send batch jobs to the cluster from Compressor while you continue to work on your G5.
    Here’s a quick setup guide on how to achieve this:
    https://forums.creativecow.net/readpost/8/1043581
  • Chris Gorman
    November 10, 2009 at 4:09 am
    Yes, I’ve seen the WD Tv before and agree it looked great. It’s a great price, until you add on the HDTV. The combo would probably cost me more than the mac mini.
    Though I wouldn’t rule it out totally, the obstacle to the WD Tv plus HDTV solution is that I’m not prepared to buy an HDTV, and if I did, I’m not even sure how convenient it would be to lug around…how much heavier than my 23″ Cinema Display?
    My Cinema Display has limitations with ambient light, but at least I know what to expect, and I already own it.
    With an HDTV there’s so much guesswork about what will display my video best considering viewer distance from the screen, lighting, HDTV specs. etc etc. weight, best specs to get for good quality, but keeping cost down. The cheaper the better. . . if it does the job, but with so many HDTV choices, I don’t know what would be the best choice for this purpose.
    For comparison purposes, I guess I’m looking at: will I get more use, more value, from the mac mini or from a WDTV and HDTV combo for same total price, eg. $600.
  • Chris Gorman
    November 10, 2009 at 4:56 am
    Thanks for the detailed response. I’m seriously considering this.
    Hopefully, the mac mini slower drive won’t be a bottleneck. Seems the CPU would be the main factor.
    I would want to run it in the background so I can continue editing on my G5, or, if possible, just put the source file on the mac mini and have the whole thing run from there..if that’s possible.
    I hope it wouldn’t be a problem if the mac mini is running snow leopard, but my G5 is running Tiger with compressor 3.0.5
    Well, I have lots to read and research, thanks for the info.
  • Chris Gorman
    November 11, 2009 at 12:26 am
    Looks like I can’t use the new mac mini as a render node with my G5. I talked with an Apple sales rep today and he said that I’d need a separate license to use the mac mini as a render node and that’s no longer available because that version of the software is longer sold. But the bigger problem is that my G5 in not an intel machine, so it could not communicate with the intel mac mini.
    I don’t think I want to spend $600 for a mac mini and only use it to display my video demos at shows.
    So, now I’m instead looking at the option of getting the WDTV and an HDTV. Maybe Samsung 720p 32″ LN32B360. It’s not 1080p or 1080i, but my h.264 files are not full frame anyway.I don’t have the tech expertise to know if the 720p will compromise the image/playback quality. Anybody have any thoughts on that?
  • Alan Okey
    November 11, 2009 at 12:54 am
    [chris gorman] “But the bigger problem is that my G5 in not an intel machine, so it could not communicate with the intel mac mini. “
    Not true at all. I recently set up an Intel Mac Mini render node for a friend with a G5, and it works perfectly.
  • Chris Gorman
    November 11, 2009 at 12:59 am
    I think the G5 that came out immediately after mine was an Intel Mac. But mine is PowerMac. Are you sure your friend’s G5 was PowerMac?
  • Alan Okey
    November 11, 2009 at 1:15 am
    [chris gorman] “Are you sure your friend’s G5 was PowerMac?”
    I’m positive. It’s a Power Mac G5 (PowerPC, not Intel). I have also set up a cluster at another location with a new Mac Pro (Intel) and an older Power Mac G5 (PowerPC).
    Power Mac G5 = PowerPC, Mac Pro = Intel Xeon.
    Who told you that an Intel Mac can’t “talk” to a PowerPC Mac?
    It’s really a moot point however, since you don’t have a license for the second computer.
