Activity Forums Adobe After Effects Mac is responding slowly
  • Mac is responding slowly
    Posted by Michael Freedman on August 3, 2012 at 10:07 am
    Hello,
    I’m using After Effects CS5 to design and animate a title sequence. It’s a fairly straight forward HD project. I’m using the camera and working within a 3D space with images that I’ve created in illustrator and photoshop, as well as some video footage for textures from stock libraries. It’s not jam packed with complex commands however it’s taking a long time to render any new actions. I was wondering if anyone has any suggestions on how I can speed up my system? Are there any preferences that I should consider which could slow my machine down? These are the specs of my machine:
    Model Name: Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 2.66 GHz
    Number Of Processors: 2
    Total Number Of Cores: 4
    L2 Cache (per processor): 4 MB
    Memory: 7 GB
    Bus Speed: 1.33 GHz
    Boot ROM Version: MP11.005C.B08
    SMC Version (system): 1.7f10
    Graphics Card:
    NVIDIA GeForce 8800 GT:
    Chipset Model: NVIDIA GeForce 8800 GT
    Type: GPU
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0602
    Revision ID: 0x00a2
    ROM Revision: 3233
    Any suggestions would be greatly appreciated.
    Thanks, Michael.
    Michael F
    Michael Freedman replied 14 years, 1 month ago 4 Members · 6 Replies
  • Roland R. kahlenberg
    August 3, 2012 at 12:12 pm
    You don’t have much RAM. Are you running AE with other apps running in the background? What are your Memory and MP settings like in AE’s Prefs?
    What are you actually doing that makes AE ‘seem’ slow? Is there anything specific that is more painful or is your entire experience within AE just doggone slow.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Michael Freedman
    August 3, 2012 at 12:33 pm
    Hey RoRK,
    Memory settings are:
    Installed RAM: 7gb
    RAM reserved for other apps: 1.5 gb
    RAM available for AE: 5.5 GB
    MP settings are:
    Render Multiple Frames Simultaneously – ticked
    Installed CPUS: 4
    CPU’s reserved for other apps: 0
    Ram allocation per background CPU: 0.75 GB
    Actual CPU’s that will be used : 4
    It’s particularly slow when I use the camera in 3D space but over it seems quite sluggish. I always make sure that I don’t have other pro apps open, only AE and safari.
    How much more RAM do I realistically need to get it moving faster? Does my graphics card have anything to do with it?
    Michael F
  • Walter Soyka
    August 3, 2012 at 1:12 pm
    [Michael Freedman] “Memory settings are:
    Installed RAM: 7gb
    MP settings are:
    Installed CPUS: 4
    Actual CPU’s that will be used : 4”
    I think your memory/MP settings are way too aggressive, and that you are experiencing poor performance because you are starving the render processes of RAM.
    Multiprocessing really balances CPU, RAM, and disk utilization. It’s more important to maximize render speed than it is to maximize CPU utilization, because the CPU may be bottlenecked by RAM.
    In other words, you may get faster renders using only two or three CPU cores with good memory/MP settings than using all four cores with these aggressive memory/MP settings.
    The Adobe recommendations for multi-processing with 8 GB of RAM installed is 2 GB for other apps and 1.5 GB minimum allocation per CPU.
    [Michael Freedman] “How much more RAM do I realistically need to get it moving faster?”
    I recommend a minimum 4 GB per core: some for system overhead, and 3 GB for each core for rendering. For a quad-core system, I’d be shooting for 16-24 GB of RAM. It should be pretty cheap to upgrade the RAM for 2006 Mac Pro, and it will give you a very noticeable boost in performance.
    [Michael Freedman] “Does my graphics card have anything to do with it?”
    Nope. There are some new GPU-related features in CS6, but none of them relate to your issue here.
    Walter Soyka
  • Michael Freedman
    August 3, 2012 at 2:22 pm
    I’ve got a dual core intel xeon, so you’re suggesting 12GB RAM for better performance?
    Also I’ve adjusted my memory settings in after effects to read:
    Installed RAM: 7gb
    RAM reserved for other apps: 2 gb
    RAM available for AE: 5 GB
    MP settings are:
    Installed CPUS: 4
    CPU’s reserved for other apps: 2
    Actual CPU’s that will be used : 2
    Do you reckon this is it better?
    Michael F
  • Dave Simpson
    August 3, 2012 at 2:53 pm
    Along with the suggestions from Roland and Walter you may want try launching Activity Monitor to see what else is going on in the background. I don’t know what OS you have but I do know there is a bug with Snow Leopard where a process called Quick Look Helper sometimes steals a large bunch of your Ram. You can just use the Quit Process button if that is the case. I know When AE gets REALLY sluggish for me that’s usually the culprit.
  • Michael Freedman
    August 3, 2012 at 3:07 pm
    Thanks, that has made a difference. Didn’t realise Spotify uses up so much RAM!
    Michael F
