Activity Forums Adobe After Effects Mac Intel and Software Compatibility
  • Mac Intel and Software Compatibility
    Posted by Dan Fredley on May 24, 2007 at 6:36 pm
    I’m about to buy a new Intel MacBook and I just have a few questions that I haven’t been able to find sufficient answers to:
    Can I run Final Cut Pro HD (4.5) on the new MacBook?
    Can I run Adobe CS2(Photoshop, Illustrator)?
    Can I run After Effects 6.5?
    In other words, I’d rather not spend money on updates if I don’t have to.
    Thanks.
    dfred
    Trevor Ward replied 19 years, 2 months ago 4 Members · 4 Replies
  • Kevin Camp
    May 24, 2007 at 8:34 pm
    illustrator cs2 will run on an intel mac, i’ve been running it for 6 months on a mac pro with no issues to speak of.
    ae6.5 should run as well as ae7 which i have been running for the same amount of time. there are problems with opengl accelerated effects and cycore effects that are bundled with ae, but it works well if you avoid those.
    fcp, i don’t have.
    i might consider buying a used powerbook, though… if you don’t want to upgrade your software to universal binaries, why upgrade to an intel mac? i’m not sure how big of a performance upgrade you are going to get without the ub software. or are you planning to upgrade later when you have the funds?
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Big Beres
    May 25, 2007 at 2:16 am
    I’ve got both a Macbook and 20″iMac, I’d forget about running FCP on the Macbook not unless you get a MacBook Pro, AE 7 and PS CS2 also run slowly on my Macbook and great on the iMac.
    If you have the money get yourself the MacBook Pro (if the laptop is what you want)
    My 2 Cents anyway
    BB
  • Dan Fredley
    May 30, 2007 at 2:38 pm
    Thanks for all your comments. That helps a lot.
  • Trevor Ward
    June 11, 2007 at 4:01 pm
    FCP 4.5 won’t run on the mac book pro. I found out the hard way. It requires AGP graphics. The macbook pro uses PCI. You’ll have to upgrade to 5.1.1.
    -trevor ward
    http://www.redeyevideoproductions.com
    orlando, fl
