Activity › Forums › Maxon Cinema 4D › Mac G5 and C4D
Mac G5 and C4D
Posted by Subspecies on December 20, 2005 at 7:41 pmhi all,
does anyone know if C4D 9 takes advantage of a dual processor?
are there any tricks to speeding up renders?
thx
Scott Frizzle replied 20 years, 9 months ago 4 Members · 5 Replies -
Adamt
December 20, 2005 at 8:01 pmCinema absolutely takes advantage of dual processors. On the Mac I think you should see a speedup around 1.8-1.9 times for a dual. I’ve seen some pretty stunning benchmarks from the new quad too. 🙂
There are many many tricks to speeding up renders, but you’ll have to be more specific about your scene(s).
Noah Kadner
December 21, 2005 at 12:20 amDefinitely rocks on the G5- you can see both processors working on separate parts of the image. On a quad core I’d imagine you’d see all 4. Can’t wait for that. With 3 Quad cores you’d have a twelve processor renderfarm!
Noah
Scott Frizzle
December 21, 2005 at 7:55 pmAh yes, those 4 lines dicing up your image is a sight to behold on the Quad (just got mine last week.)
Cinema takes full advantage of as many processors as you have. It runs great on both the dual and quad G5’s.
Noah Kadner
December 22, 2005 at 3:18 amSo if you have the 3 CPU net render license with 3 quad cores- you’re good with 12 procs right?
Noah
Scott Frizzle
December 23, 2005 at 8:31 pmYes, that’s right.
Of course as with any new gear, your render times will not drop, you’ll just crank up your settings and end up right where you began, although with slightly prettier renders. 😉
