Activity › Forums › Apple Final Cut Pro Legacy › MAC file transfer problem
  • MAC file transfer problem
    Posted by Tom Mooney on April 23, 2007 at 3:01 pm
    We have a G4 867 that is used in a FCP off-line editing suite. We are a having problems transferring files from this computer to another computer. We have several flash drives and 20GB smart disks that we use to move files. When they are hooked to this computer the transfer rate is very slow. It take 3 minutes just to transfer 100mg of files. Every other MAC and PC uses the disks OK and tranfers the data fast.
    The computer has no problems with any fire wire drives, but I hate using them because they need power and you need to move the power supply; it is pain if you are moving files 10 times a day. Anybody see this problem with an older MAC?
    Ben Oliver replied 19 years, 5 months ago 4 Members · 3 Replies
  • Debe
    April 23, 2007 at 3:05 pm
    It’s probably because it’s only capable of USB 1.0, and all your other Macs use USB 2.0.
    How about getting a bus-powered FW drive?
    debe
  • Steve Eisen
    April 23, 2007 at 3:11 pm
    If your computers are close by, connect them via gigabit ethernet.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Ben Oliver
    April 23, 2007 at 5:53 pm
    you can get a long firewire cable, and boot the g4 into target mode? restart and hold “T”
