Activity › Forums › Apple Final Cut Pro Legacy › MAC DVI to SDI/componet for production monitor from FCP
  • Walter Biscardi
    December 8, 2006 at 10:26 pm
    [MtClimber] “G-5, 2.5 GHz, 8 GB Ram Mac OS X (10.4.8) Nvidia Geforce 6800, 30″ Cinema DisplayI will be hooking up a new Panasonic HD professional production monitor (BT-LH2600W) to my G5. I only need to monitor from Final Cut Pro’s Timeline; no input or output needed (like from a Kona Card).”
    No you still want true HD video from a video card, not from the DVI output. At the very least get a Kona LH for monitoring.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Brian Rennie
    December 8, 2006 at 10:33 pm
    What about a Matrox MXO. One concern is using it with my G5 and my MacBook Pro.
    https://www.matrox.com/video/products/mxo/connect.cfm
  • Walter Biscardi
    December 8, 2006 at 10:36 pm
    [MtClimber] “What about a Matrox MXO. One concern is using it with my G5 and my MacBook Pro.”
    someone else will have to chime in on that. I don’t use Matrox products.
  • Aaron Neitz
    December 9, 2006 at 1:16 am
    You can get a HD Blackmagic card for, what, $500? Then you are guaranteed to have a professional SDI signal to feed that monitor.
  • Dan Riley
    December 9, 2006 at 3:01 am
    Actually the lowest priced HD card from BM is $995. But it’s still the way to go over
    using DVI out of FCP. As for using a Macbook Pro for HD monitoring, well
    then you WILL have to use the DVI out into a converter like this one
    if you want HD SDI output:
    https://www.gefen.com/kvm/product.jsp?prod_id=3874
    Dan
  • Sean Oneil
    December 10, 2006 at 6:47 am
    Do NOT get that Gefen thing. It’s just a dumb converter. Your monitor output is NOT a real video signal and Cinema Desktop mode does not have the proper timing and colorspace as a real video signal would.
    The Matrox product is different. It’s not just a dumb converter. It was specifically designed to achieve what you are looking for. It uses software and hardware so that the output signal will be a proper video signal. I haven’t used it myself, but I can assure you it was meant for this. The Gefen thing is not.
    But of course get a real card instead if you have a desktop. Aside from economics, you get better features and you won’t lose a computer monitor in the process. The Matrox thing only makes sense for laptops.
    Sean
  • Brian Rennie
    December 10, 2006 at 6:45 pm
    that is kink of what I figured. So if you have a G5 and a MacBook Pro, you will need 2.
    Do you need this converter for the laptop if you will only be concerned with showing a finished movie, say quicktime or from the timeline to a TV?
    I would probably use the laptop to take to places to show a finished Hi Def Movie.
